Hey I have an Armoured 2010 Explorer, It has like 200 kilos more than stock. I was wondering if I could change stock tires for BFGoodrich All Terrain. Thanks
:rangertan:
yes you can, BFGoodrich All Terrain T/A KO is rated for higher load than stock tires. try to find same size as stock tires or slightly larger and you will be fine.
Just do not exceed 5% larger or you will need to re-gear your differentials.
