fourbyfour, mount to mount would be awesome.
Since so many thing in mine are changed, this is the one reliable thing I can still measure easily.
I do have some more pictures, but they're just of the truck in my garage rather than out at the roof chop guys yard.
I did however do the drop by backing out the adjuster bolts, it now sits really now.
All the other progress is less obvious, I now have a TIG welder so I can do my own welding, and I've bought a 49 car dash to replace the ugly truck dash. It needs to narrowed about 6 inches total but will look cool, the speaker grille hole will serve as a good access for...
...An under dash 90 degree brake pedal setup from Kugel Komponents - obviously being auto I'll just have a one pedal version.
I've also really roughly mounted the Ex steering column so I can steer it, the location is pretty easy, and I will finalize it once the TM headers arrive next week.
Also, since I've decided to do a channel, there will be some serious dismantling going on very shortly. I've started wire brushing and cleaning up all the spot welds I'll need drill out to raise the floor.
Things have been tight financially but that fog is lifting now so I hope to have a lot more to show soon.
