- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Basiclly, it is comming from F150. It is not seen in Turkey.
It has nothing to do with American cars. All sorts of AWD cars have viscous couplings. They all use the same principle.
Ditto, any actual AWD transfer case has to have internal parts that allow enough "differentiation" for turning wheels(different shaft speeds). But lots of vehicles may be called AWD or confused with odd descriptions, and not actually be AWD. The V6 Explorer versions you see over there are either 2WD, or automatic 4WD(A4WD). That's the one people often think is AWD, but those have a clutch inside which is disengaged most of the time.
I also would want to have the vehicle repaired, by a very reputable place that will document every detail of the work. The black ATF that comes out wouldn't be absolute proof, but it would prove that there is a huge amount of wear of the viscous clutch inside. That TC fluid should be replaced regularly, what are the chances that you had that done last year?
