- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
The firewall is way different for a gen ii
The cutouts for the hvac box and steering column / wiring changed a great deal
The gen ii dash does not fit the same, meaning your bii came with the early 83-88 style dash and the 89-94 style dash, but never with the 95+’style so it’s not a bolt in deal
The 5.0
Computer is obd2 so you will want to add a obd2 port to your dash or engine bay for talking to a scanner
I am still rocking my 1988 dash with the 97 5.0 and computer. The stock tachometer was near impossible to get working with the 5.0 and the speedometer no longer has a cable with the 302
You can use the guts of a early 90s mustang or f150 tach inside your stock
Cluster and get the tach reading properly
Your speedometer is cable
Driven, with the right transfer case vss setup you can keep the cable and sensor.
So all of my gauges are aftermarket even fuel
I Am using a floor shifter from a 96 mustang in my bii, made custom center console to hold it
I have also done it like you are, we took a 83 ranger and converted it to 4.0 using the dash and wiring from a 92, then later we went 5.0
The 92 dash works well with the 5.0, the stock speedo and tachometer can be made to work but there was still lots of customizing to do. It modified the 92 steering column to hold a 97 style column shifter and od button on that truck
Still Managed to stuff ac, cruise control, two batteries all under the 83 hood.
Basically you will remove the 4.0 drivetrain harness and ignition wiring. Keep the 4.0 power distribution box and dash
The 5.0
Starting and charging wiring is far superior
It the early bii stuff,
Wire routing got shorter and more direct with less connections over the years. So rip all that old 80s 2.9
Wiring out and only
Keep the good parts of the 4.0
Which is the nice 93/94 style power dist box
My bii is 1988 dash 93 power distribtion box and 97 5.0
PCM and harness laid on top. I am using a 90 bronco ii fuel sending unit in tank with a
Walbro pump. I put a second filter on the frame rail
Where the factory 1988 high pressure fuel pump used to be and I am using the stock 1988 Evap line and fuel return line from the tank. I added a fuel tank pressure sensor. I am using 93 4.0
Canister purge valve with the 97 5.0 pcm the canister vent solenoid is wired in but open to atmosphere (no codes)
If I was to do it again I would ditch the fuel return line and run the 98-01 style returnless injectors and fuel rail, modify the 90 bii pumping regulator from a gen ii
Where the dash and body mate to the old 4.0, at the big white plug (firewall) is where most of your wired for the 5.0
D train can be found. Others like ac stuff and alternator charging and starting harness will get chopped up so the obd1 dash works the obd2 pcm and drivetrain.
The 5.0 obd2 wiring has been hacked now lots of info out there on what stays and what goes. I have converted trucks from 83 all the way to 07 to 5.0 now.
The 5.0 drivetrain from the explorer is very “stand alone”
Meaning it could easily be run on an engine stand with the right wires hooked up. Once you remove all the “fluff”
Wiring from the engine bay and dash you are left with a computer that runs and engine and a trans and only a few wires needed from ignition fuel emissions and dash to make it happy.
It is mOre compact then the 4.0
Systems that you are removing
And once it’s under your hood you will find it’s easier to work on too! Hahaha
That cologne v6 stuff is hard access, the 5.0
Makes more sense
I did my bii in 2005… almost 20 years of v8 driving, best upgrade possible!!
The 5.0
The 5.0
Wiring out and only
Makes more sense
