- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Most of the VB kit parts go into the VB itself, which isn't altered in a rebuild. There are a couple of springs etc that replace those just inside the case. Most rebuilds don't change any of those kinds of parts unless they seem damaged or worn. So unless the rebuilder goes about changing odd parts trying to guess at the cause for an issue, all of the VB kit work is left intact. I would of course tell a shop doing a rebuild whether the trans had any recent work done or parts replaced. That helps them to know what to look for and to leave alone.
I have a 94 Mustang GT that I might later get running again(it's wrecked), and for its mild stock condition I'd do the TransGo kit in it. But that's a 94 AODE which isn't quite as good as the 98+ 4R70W. It would also need a couple of other upgrade parts that are stock on 98+ transmissions.
Check on eBay and see what variety of pricing is there for the HD kit, the one that is always over $60 or so. TransGo has a basic correction kit that used to cost $26 or so, but now is over $40. That's a fine kit for just a basic tweak of a trans, it doesn't do as much.
