BD's 2000 Explorer Limited | Page 15 | Ford Explorer Forums
Pictures really do no justice for these tires, but
I absolutely love em! Not any more road noise than before, but they do pick up some more bumps.
God its so nice to be able to feel safe driving again! And let go of the wheel and go perfectly straight down the road.
...Not that I do that:p:
Those spots on the hood are killing me now! I think I might tackle that and fill those licence plate holes in the bumper in the next week or so when I get some time off work.
Also did my 0 gauge wiring, ive had it laying around for 3 weeks now
The grille went alot easier than I thought, but took so much more time. Its a used one, so it has some paint chipping/corrosion, but nothing some sanding cant fix. I plan on sanding it down and painting it glossy black real soon. I also need to touch up a few spots on the grill surround itself, I slipped with the dremmel :p: and id like to possibly bondo (Or something simaler) to fill the holes from the old grill posts, I can only imagine thats gonna look like ass in the direct sunlight.
Truck looks good, Brian.
Thanks bud, shes definitely a work in progress. I really want to rIp the running boards off and get some rocker panels on there but im scared. I just honestly don't know what I'd do when i see What i can only imagine is under them, lol.
Calm- there will be nothing to see under the running boards.
Literally- nothing. :O
Thats what I dont want to see! - Nothing!!
Im hoping to score some rockers (Cheap) on CL or something, do they just bolt on the same way the running boards do?
You'll have to mount aftermarket rockers another way, the stock type attach with holes that are up under the inside of the body, with brackets.
You will have a bunch of holes to fill, all along the fender flares.
Oh no! I didnt realize the fenders were part of the boards :(
I like my flares. Well, looks like no rockers until I score some new flares too! (JY)
Tomorrow my mission is to fix my windshield squirter pump, its been a tricky SOB. When I first got the truck, the fronts squirted like new, back didnt squirt. I found a small kink in the line, and then the back worked fine. Then the front quit for a week but the back still worked. (Wipers always wipe, but no juice), then it worked fine. Then after that first good snow, I had barely any pressure coming out, enough to barely hit the bottom 5" of the windshield.
Now its just completely dead. (Nothing squirts), wipers wipe, and like usual, the back works. I found a few threads suggesting to check the relay, tap the motor itself to see if its stuck (Which I wouldnt think either are wrong since the back window works) Are there 2 seperate relays?
And now im noticing when my front tires spin, my ABS light comes on (And stays on til I shut it off, and start it back up).
Im also wanting new shocks terribly, im traveling on back roads about 90% of the time now, and some are just awful, seems like my wheels are hopin, and im bouncing all over. I know obviously replace shocks in pairs, but how about the rears?
ARGH! Those small spots on the hood, and behind the grille (Where the old grill was cut) are killing me!
Bigger :D
those rust spots?
you should paint the part where the grille was cut black to make it look nice, no sense in trying to hack it all up trying to make it look perfect, I've done that a few times and it just turns out worse than before
of course I've tried to paint a few times and it comes out worse than before...
Hm, thats a good idea, never thought of that. But yea those are rust spots, the camera just makes them POP, they dont look that bad in person thank goodness:)
Spring is gonna be busy as HELL for me :D
Well after some research on shocks, I know im also doing them myself. (Figured it was gonna require taking off the knuckle and all that crap again!)
So far, im looking into MONROE Sensa-Trac's for the back.
http://www.rockauto.com/catalog/moreinfo.php?pk=60655
(But what about the "5th" shock, should I just get a decent single shock for it? (The Sensa's come in sets of 2)
And for the fronts, maybe the Sensa Trac's, but im still looking. I just got off Rock, and im checking www.ShockWarehouse.com
OK- Now ive read alot of suggestions on the KYB's. I found a set of 4 on SW for 116$ shipped, but that just seems SO cheap.
http://www.shockwarehouse.com/site/...41302-KYB-GR2-Ford,-Mazda,-and-Mercury-Trucks (Those are the fronts), im looking for improved handling, no bouncing over bumps, but nothing thats gonna make it ride harder than it does right now, that'd be ridiculous!
dont even bother with that 5 "shock" and technically its a stabilizer. I took mine off and I don't even feel a difference. Mine pretty much rusted through the casing too, but the rod was still nice and shiny.
I'd go with billsteins. I have rancho 5000 but before I had billsteins they were nice on the road. Were on the truck for 80,000 miles and the fronts had worn down a little but not too much. Billsteins might be expensive but worth the price.
Monroe makes good shocks too but, I heard don't last long, never had them though
Do you have ARC?
Edit: After doing some research monroes make ranchos too...My rancho shocks are holding up well, I do abuse them sometimes though :)
Change the fifth shock if you like a good handling vehicle. It only helps to reduce the side to side movement during cornering, which is not noticed by anyone. I could feel the improvement with my Bilstein shocks, all five of them.
For street use the Bilsteins are the standard, Koni's are the best. For off road use, you end up with Rancho's or a couple of other good brands. I have the Rancho/Monroe Reflex for the front of my 99 truck, due to being cheaper and guaranteed for life. Spend at least $40 each, anything less is a cheap shock that will not last all that long. Regards,
And Rock is cheaper than ShockWarehouse, even with our 'special deal' here.
I like the Reflex better than the Sensatrac, and I've had both...
Do you have ARC?
I do not believe I have the ARC, I have "glanced" at my rear shocks but dont see anything out of the norm. Once in a blue moon I like to get off the pavement and get her dirty, but nothing like rockclimbing :p: Just minor mud and hills :D
Yea, from what ive read on the forums, it seems like everyone has theyre own opinion on that one. I for sure will be replacing it, but ill probably take the old one off first JUST to see how much of a difference it makes...im curious...But yea thats funny you say the 40$ thing, that was my cheapest. I was looking at a set of 4 KYB's shipped from SW for like $130 but the fact that theyre only about 28$ a piece, I kinda leaned away from them quickly after some more research.
Ill be honest, I dont really care for the way SW.com is setup, im gonna look into the Reflexes, what Ex did you have 'em on? How many miles were on the previous set (Im assuming probably the stock shocks?)
chuck that 5th shock in the trash and Fox shock the whole truck, than you won't even need swaybars either
Ya know I was looking at those too...4 of em, WITH the Chrome Plating....Hell yea!
It'd only set me back a little:shifty_ey
Subtotal:
$1960.00
Shipping*:
$0.00
California Sales Tax 8.75%:
$171.50
Total:
$2131.50
thy can be had alot cheaper than that, you just need the smoothies, and they are alot cheaper,,
i have seen them for less than $150 each , and they are super bling,,
and they would last the life of your Explorer,
