Need some opinions:
I am permanent mounting my air tank and compressor. Its a Puma 12 volt and its large. I can mount it in one of two locations. Either, the compressor can mount into the fender well under the interior panel as shown below, with the tank underneath where the spare tire used to dwell (tank doesn't fit where I had hoped in front of the axle), or I can keep the compressor mounted to the tank and just mount both in the old spare tire well.
Pros/cons with both locations:
Inner Fender compressor, spare tire well tank: Cons; it will be loud in the cabin area, I have to run a bunch of wiring and hose, and it might have overheating issues. The plan if it goes here is to cut a 4" circular hole in the interior panel directly above/around where the cooling fins are located. Will still need to make some type of removable cradle for the tank to help protect it from the elements, and be able to remove the auxiliary battery that is also under there.
Pros; it will be protected from the elements, and sit upright.
Compressor and tank in spare tire well: Cons; compressor will be exposed to the elements, compressor will be on its side (don't know if that's an issue), will have to construct some type of case that allows air flow but protects unit from the elements, and is easily removed to remove auxiliary battery.
Pros; compressor and tank will be as built, no need to run extra hose, wiring up will be a breeze, just one relay with a "on in run" wire to activate, only need to relocate the regulator/hose connection to a more accessible location.
Opinions / Suggestions???
Pics of inner fender mounting location:
