Spent a marathon 10 hour day working on the Explorer. Got the oil pan out and back in with the correct gasket. Hope it doesn't leak, because its a royal pain. There is a hard plastic seal called a "wedge seal" at the back of the engine. The existing one looked hard and brittle. Yep, it came out in pieces. I spent a few hours chipping little pieces of it out of the sides of the crank housing. The long torx bolt at the rear of the pan is very hard to get started with the transmission in place. I bet on a stand with the engine upside-down, it would be a lot easier. The engineer that designed that engine needs to be kicked in the nuts.
I got a Felpro gasket set and it came with these little screw in plastic guides that are supposed to make it easier to install the pan. I tried them, and while I was shifting the pan around to get the long bolt mentioned above started, one of them broke off inside a bolt hole. I had to continue the install because I was afraid the RTV would set before I could get it tightened down. After I got in every other bolt, I drilled out the plastic stuck in the bolt hole and installed the last bolt. And I thought the intake was going to be the hard part.
Got most of the upper engine stuff back in place. I rerouted some of the wiring harnesses and vacuum lines and still need to clean them up a little more before I install the alternator and upper radiator hose. Going to wait until Monday to give the sealant time to set before I install the transmission bolts that go into the back of the oil pan. With the 700R4 transmission, I think their only purpose is to help the engine / transmission aluminum adaptor stay rigid. Also need to reinstall the trans bell housing (needed to remove to get to the trans bolts), the starter, oil level sensor, and add coolant and oil. After that, I still have to reinstall the engine cross member, and the cross member at the transmission / engine that holds the front of my skid plate. Going to wait on those last items until the engine is running for a while because with them out of the way its easier to spot leaks.
