- November 29, 2000
- Location
- USA
- San Diego, PRofK
- 1994 XLT
I think this is going to work!
I think so too. Took it on a road test today. It never got over 180, even up a mile grade with it in 3rd and floored. Normal temp was around 150-160, which is where that trans is supposed to be at. Took a while to get to 150 but with the synthetic fluid it should shouldn't ever be an issue, unless I am out wheelin' in 20 below temps (not likely). Engine did not get above the "R" in Normal. It usually gets warmer faster. I think the trans guy was right and they engine and trans were heating each other up.
Best part, it is not leaking. I am going to take it on a longer trip to make sure its a done deal, then work on replacing the hose with steel lines. Its fairly inexpensive, and is great piece of mind for those long, multi-day adventures.
