BMXking's Axle Swap 1st gen. Coils/Radius Arms!!! | Page 16 | Ford Explorer Forums
not to worry though.. I left the stasher his hoses and cables and crap and the one rotor that I could get off! Hope they are the right ones.
Wheel studs for disc conversion, BC Bronco's adjustable trac bar, and Bronco Graveyard EB adjustable trac bar mount. I also got a spanner nut socket so I can get those knuckles back in and set the preload, etc.
OK you need to go outside right now with a grinder and start cutting your stock front end out. You have been planning FOREVER.
sooner or later you gotta man up and start doing it.
In all seriousness though, looking like it will be sweet once its all done
I just started the swap. I'm pulling out the rear as we speak...
geez after 304 posts, I was wondering what the hurry was :D
sounds like its finaly time for some in process pics
Thank the good lord above.
Get on it Bryan!
REAR AXLE
-1983 Ford 9" $85
where did you acuire this at for 85 bucks
Just Bring On The Pics !!! you probably need to start a new thread after like 311 posts about it tho lol
Haha, I'll post some more pics in a little bit. Just got off work so I'll go work it some more in a few.
James, I got the rear axle from the Pull-A-Part on Buford Hwy.
Glad to see your getting it started finally. After not looking at this thread for like a month and a half, Im happy something is finally getting done. :p
J/K Lets see some pics of that rear ripped out.
well im very anxious for some pics...lets get em' rollin'
wheres the updates ?
I've been working a lot lately. And as you know, it's been some crazy ass weather (warm weather, then rain, rain, more rain, cold, and now tonight it's supposed to flurry) :confused:
The rear axle is still sitting under the truck, but it's only held in by a brake line and the sensor in the diff. These will both be coming off tomorrow, then I'll be mocking up the 9" under there....which will be getting the new perches and shock mounts welded on, on Monday. From there, I'll just need to buy my rear calipers (doing that first thing next week) and build the caliper brackets. My parents are paying for the rear driveshaft to be extended so once I get the rear bolted up under there and have a rolling chassis again, I'm going to take it to Doraville Driveline to be extended. The tires and wheels are being mounted and balanced at 4 Wheel Drive Parts Center for free (it's nice to work next door :D) on Monday or Tuesday. The steering is also being ordered from them at the same time...
I'll post the pics I've got in about 10 minutes.
Sounds like you got the ball rolling with your SAS! Good luck on your swap!! Can't wait to see some pics.
Why are you have an extended rear DS? Are you moving the rear axle?
No....the rear axle is staying where it's at. I'll need a longer driveshaft because of the fact that I'll be running about 8" of lift. Everyone I've talked to needed their's extended when they went over 6". Heck, even jrgaylor told me he eventually had to have his extended 4"!!! Plus, I can have a 1330 put on the end so I won't need to run a ******* u-joint.
Finally some real progress pics...
Here's some pics of the temporary ride. It's a 94 Sonoma 2wd. My bro just turned 16 it'll be his truck once he gets his license. I was TRYING to talk him into a lift and 33s, and he agreed for a while, but now decided to do 3" drop all around, 17s, new exhaust, K&N, roll pan, etc. Should be pretty nice once he gets started on it.
mroe pics...
