BMXking's Truck | Page 8 | Ford Explorer - Ford Ranger Forums - Serious Explorations
BMXking's Truck
I can finally post my truck here!!! :bounce:
This is what it looked like when my parents bought it in the spring of '03.
1993 Ford Explorer Sport 4x4 - 125k miles, 5 spd. trans, loaded (except for leather seats) $2000
Here are the mods:
-Panasonic Head Unit $100
-Boston Acoustics Speakers $100
-Painted the Orange Stripe Black $FREE
-Custom Magnaflow Cat-Back Exhaust $210
-Husky Cargo Mat $50
-New Dark Green Paint Job $550
-Neoprene Seat Covers $25
-Throttle Cable Mod $FREE
-Brushed Aluminum Gauge Overlay $10
-Diamond Headlights, Clear Corners & Side Markers $125
-Sylvania Silverstars $40
-Heavy-Duty Flasher for Towing $5
-Diamond Plate Door Sill Protectors $FREE
-Skyjacker Nitro8000 shocks w/ Poly Bushings in rear $80
-Steel Center Arm Rest Bracket $25
-New Fender Flares from Mazda Navajo $60
-Pro Comp Tow Hooks in front $10
-Keeper 20' Recovery Strap $15
-Serious Explorations stickers $10
-Removed Front and Rear Sway Bar $FREE
-Cobra 19 DX III Mobile CB $15
-Wilson "Little Wil" Antenna w/ 3ft. whip $25
-PA Speaker $5
-Receiver Shackle $25
-New Ford Steering Box $90
-Extended Diff. & T-case Vent Tubes to Engine Compartment $10
-Hi-Lift 48" Cast & Steel Jack w/ Hi-Lift poly jack strap $10
-K&N Breather on Top of Diff/Tranny Vent Tubes $FREE
-Sliders(.120 wall, 1.5" DOM) $250
-K&N Air Filter In Basement(For the Snorkel in the Future)
-KKM Intake $25
-Yakima Cross Bars $20
-S-hooks (To pull back inner fender) $FREE
-Optima Red Top Battery $110
-Hurst Short Throw Shifter $200
-Hard Mounted Fire Extinguisher (ABC) $10
-Centerforce Dual Friction Clutch w/ new Ford parts throughout $350
-Hella 500's on front bumper $50
-Cargo Box for Offroad Acc. $40
-Hard Mounted Camo Maglite $20
-Autovation 4x4 pedals $50
-37x12.50r16 Maxxis Creepy Crawlers $400.00
-16x8 5 on 5.5 4.25 backspacing Black Rock Crawlers $293
-Gutted Catalytic convertors$FREE
-New Flywheel, pilot bearing, and master cylinder $150
-Draw-tite tube hitch & 11" drop ball mount :eek: $130
-Q-Form Kick Panels $25
-Pyle Back-Up Camera $80
-Pyle Flip Out DVD player $400
FRONT AXLE
-1977 F-150 HP D44 Full-Width $200 - Moved Forward ~1.5”
-Myers Machine Coil Seats $40 shipped
-6* Pro Comp Pinion shims under coil buckets (to fix coil angle) $18
-CAGE Offroad 5.5” Coil Springs $150 shipped
-Coil Buckets Spaced Out 2.5" (3/16" x 2.5" x 6.5") $FREE
-Bronco Graveyard 78-79 Coil Spring Tower, Pair $90.80 shipped
-F250 Shock Towers $28 shipped
-Stock Axle Shafts(for now) $FREE
-Warn Premium Hubs $72
-Extended, Plated, Heimed, Wristed 1978-1979 Bronco/F-150 Radius Arms $222 shipped
-CAGE Radius Arm Mounts $FREE w/ R/A's
-Stock F150 trac bar with Energy Suspension poly bushings $5
-Skyjacker Stainless Steel Braided Lines for lifted D35 TTB's $90
-Bronco Graveyard 66-75 Early Bronco Adj. Bracket $45
-New F150 tie-rods & stock Explorer drag link (w/ red poly dust boots) $121
-Stock pitman arm $FREE
-Raybestos Professional Grade $19.95 shipped, Powerslot slotted rotors $120
-Completely rebuilt (seals/bearings/ball joints/u-joints/etc.) $200
-Energy Suspension Red 7* C-Bushings $22
-Stock Explorer D-shaft w/ 1310 D44 pinion yoke for stock Explorer u-joints $FREE
-Rancho RS5000 shocks $20
REAR AXLE
-1983 Ford 9" $85
-Rubicon Express Anti-Wrap perches welded SOA $35
-Wild Horses Weld-On Shock Mounts $15
-Stock Springs w/ AAL $FREE
-Stock Axle shafts $FREE
-94-99 Dodge Ram 1500 front rotors $58 shipped
-'76 Cadallic Eldorado Calipers w/ e-brake $150 w/ core calipers
-'78 F150 Extended Stainless Steel Braided Rear Brake Hose $45.34
-Custom Bent Brake Lines (w/ 3/8" ends) $8
-'79 Caddy Eldorado Brake Line end box thing $FREE
-7/16" Banjo Bolt for '76 calipers $5
-Speedway Motors GM Large Caliper bracket (7" mounting points) $40 2-day shipped
-Cut off mounting points from Ford 9" drums to use as spacers for the disc conversion (no longer a backing plate behind the shaft) $FREE
-Third Member from eBay (4.88s, mini spool) $150
-BC Broncos Disc Brake Conversion Wheel Studs $15
-Wild Horses Super Duty U-bolt Kits $60
-Extended/balanced rear driveshaft w/ stock 1310 to match the 1310 on the axle $123.63
-Skyjacker Nitro 8000 shocks for 2" lift Explorer $FREE
TOTAL: $8431.77
Future Plans:
-Custom Front Winch Bumper w/ light mounts, d-rings
-Custom Swing-Out Tire Carrier Bumper w/ hitch, reverse lights, CB antenna, d-rings
-Roll Cage
-Tube Doors
-Rebuild transmission
-Rebuilt manual t-case swap
-Rear Buckets, Sparco's up front
-BBK throttle body
-Hi-steer conversion with Dedenbear knuckles, DOM tubing, and Chevy TRE's
-Regear front to Yukon 4.88s with ARB
-Warn Chromoly Shafts up front
-Moser 35 spline in the rear
-Nodular third member with Yukon 4.88s and 35 spline ARB
-single Magnaflow hi-flow catalytic converter
-Darkest legal window tint
This is what it looks like now:
JS91X
cumming, GA
1991 XLT
does this mean i can borrow your bad ass tires and robbie can run my bad ass baja claws or my pj dirt gripz when they come :D (35s for now)
bmxking5
Monroe, GA
'93 Sport & '96 XLT
Haha my rims won't fit your truck. Robbie and I are both running 5 on 5.5. ;)
bmxking5
Monroe, GA
'93 Sport & '96 XLT
Been a while since I've updated this. The transmission finally crapped out, so I had to get it rebuilt. It ended up taking them an extra day than they said, so I didn't get it back til the day after the show, so obviously my truck wasn't in it.
I just now got finished ordering my new tires and wheels from the new shop I work at. I'll have them as soon as I can pick them up...
-37x12.50r17 BFG Mud Terrains
-17x9 Moto Metal 951 in black (same ones I said I was going to get before).
I've also got a few more things for my system so I'll be installing all of that stuff soon as well. Pics to come soon.
sn0border88
Master Apprentice
Souderton, PA
1992 XLT
what are you doin with the old rims amd tires ;)
JS91X
cumming, GA
1991 XLT
keeping them as offroad only tires i presume...put me in line first for them if your gonna sell them ..i got cash money bro ! (just tires screw the rims)
sn0border88
Master Apprentice
Souderton, PA
1992 XLT
im definatly first in line :p:
bmxking5
Monroe, GA
'93 Sport & '96 XLT
Well, two that are still above the wear bars (have about 15% tread left) I'm selling as spares, and the other two are down to the wear bars (ones almost completely bald).
JS91X
cumming, GA
1991 XLT
damn cause i got $350 cash thats just burning a hole in my pocket and i need some tires for my yota...need to get wheels too
