- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Your list of parts looks correct, since you are putting the 4406 into the 99 truck you COULD use the 97-98 version of the 4406 as well, just leave the speed sensor unhooked.
But it sounds like you already located your parts.
I am not sure why you want to rebuild the 4406 case, I personally would skip the rebuild as long as the used case is in good working order it should last a long long time under your explorer, they are rarely abused or worn out even with 100K miles on them.
I have a front disconnect IFS axle too I was hoping to install in my 96 5.0L truck, but honestly its more trouble then its worth, in 2wd I dont notice any power loss or hard steering like I did with the AWD. If you were to install a full time front locker then the axle disconnect would be a great idea, otherwise if it doesnt fit under the truck its just not worth the extra effort to get it in there IMO
