Camshaft Position Sensor- CMP video | Ford Explorer Forums
Turdle
DIY stunt double
Staff member
Moderator
Humboldt, KS
2000 Mounty
Those type sensors usually go in-place of where the distrubutor would be. If you take that cover off you will see a hall-effect type sensor, and usually what happens is the insides will get too much play in it and start to tear apart the inside of it giving a bad reading. It can also give you a squeek.
-Drew
ps- maybe next time get someone to hold the video camera so you can hold it and spin it ;) Still a good video
I just thought that since there is ao much confusion about this part, It would make a good sticky for reference, It is a misunderstood piece
They make a lot of specialty tools. This one looks pretty unique:
It's called the OTC Ford Cam Sensor Synch Tool OTC-6469.
BrooklynBay said:
This one called the OTC Ford Cam Sensor Synch Tool OTC-6474 looks very much like a plain bar:
this is for cam alignment tool for (dohc) mystique-contour. You sluide this into a groove in each cam, then tighten sprockets.
BrooklynBay said:
This one is a master set which has everything:
It's called the OTC Ford Master Cam Tool Set OTC-6489.
Funny, this is a tool that gets used 1 time by most people.
Although that whole set is pretty sexy
ha ha ha I just remembered that tool because I had to do a head gasket on wifes Mystake, That tool is no more than 11" piece of 1/4"
steel, locks cams in place. I knew I had been ripped when I found the identical "tool" in a scrap bucket in my garage lol
GAR... why couldnt this have been posted 2 months earlier. :(
what happened?
Its the same "tool" for the Focus Zetec and Duratec engines which are also DOHC.
Jefe have you had the head off your Focus??
Head, no. Cams, soon. ;) Valve cover, yes, to replace the valve cover gasket that is a common problem for the Zetec. There's just no stopping me from tinkering, even on a car that is under warranty. :confused: I don't know why I even bothered with the extended warranty, I'd rather do the work myself. :rolleyes:
