- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Sure you take a 5.0L MAS body and sensor, find somebody who has the ability to calibrate the sensor for the OHV's 19# injectors. CHip makers, speed shops, Mustang shops. You will have to research.
If you but many aftermarket MAS sensors, 70MM or what have you, this is all they have done., My granatelli unit is nothing more then a 5.0L that this has been done too, was like $200 from truckperformance.com years ago.
You can make some phenolic spacers for the upper plenum to increase the runner length. Using a material like phenolic will also keep the upper intake cooler, as long as you are running the aluminum unit, this is WHY most upper intakes these days are plastic, cheaper to make and keeps the heat down for the incoming air, however they cannot be ported
