Can I Pull it??? | Ford Explorer - Ford Ranger Forums - Serious Explorations
Can I Pull it???
I have a 2003 Explorer with the 4.0L V6 engine, control trac 4x4, with a class 2 trailer tow package. I have a 1920# trailer while empty. How much can I actually pull witht my explorer without causing problems? Any input or suggestions would be great!! Thanks!!
JDraper
Somewhat Functional
Moderator Emeritus
McVeytown, PA
'18 XLT
A lot more than that, the Class II receiver is rated at 3500 lbs with a 350 lb max tongue weight. I'd suggest putting a good sized tranny cooler on the truck though. The transmissions are one of the weak points in the Explorer.
gburgbuck
Gibsonburg, Ohio
2003 XLS Sport 4x4
ThankS! Should I put a class 3 reciever on the truck or just stay with the class II? I know the truck is rated for more than 3500 and if I put a big tranny cooler on it that would help as well. As you can tell I am pretty much clueless.... :)
sjr033
Portage, MI
2001 SPORT
If you need to tow more than 3500, then you need a class III. The tranny cooler will not give you more towing capacity, it will help with the tranny life expectancy.
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Which rear end does it have in it?
With the OEM class 2 hitch, you'll be limited to 3500 lbs. However, the max rating will still be determined by the engine, trans, drivetrain (4wd/2wd), and gear ratio it came with from the factory. It's listed in the tables in your owner's manual.
-Joe
