Cell Phone Mount
KelvinC
Lansing MI
2013 Ruby Explorer Sport
I know this is an old thread but I'll chime in anyway. I LOVE wireless charging as it prevents the wearing of the only part of cell phones to wear out in the past and that's the charge port connector. I have LG G2/3 phones with wireless backs and an iPhone 6s (company) with a cheap wireless coil on the back under the case. The iOttie Qi suction cup mount works really well. It's not the cheapest but it works. I had to use a different 12v-USB adapter that generates more output to charge my LG. But that was easily done. The only challenge in the install was wiring the 12v female adapter into the fuse block. Not that it's difficult to make the connection - but a PITA to get to the fuse block. The engineer on this should have to change a fuse daily (or lose his job) for putting the fuse block behind 2 panels with access on your back on the driver floor. Ridiculous.
player12
Location
Southwest Missouri
2016 Explorer Sport
In my old 02 Sport the cigarette lighter was near the steering wheel which made for a nice place to mount a articulating phone mount.
I can't find a good spot to mount my phone so I can easily see it's display. It ends up sitting in a cup holder.
Anyone have pictures of a better phone mount option?
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
A quick search using the Forum's handy 'Search' feature brought up this thread to which yours has been moved.
Jon M
Mount Pleasant, SC
2015 Explorer XLT
peterk9
Staff member
Moderator
Callsign
VE3
Says it won't work with Platinum and only with standard radios. So that Excludes sports with the Sony stereo and Nav?
I believe the Limited, Sport and Platinum have the same radio setup. For 2017 the same upgraded radio is in the Sport and Platinum.
Jon M
Mount Pleasant, SC
2015 Explorer XLT
I don't know. I went by the trim it attaches to. Mine has the 8" MFT with auto climate controls and it works.
They have two others, if you search by make/model/year.
expoman55
Location
Upstate NY
Upstate NY
2015 Explorer Sport
This is what I use mounted to the left of MFT . NOthing mounted to phone. I placed the small metal very thin plate inside back of my case.
SCOSCHE MAGDM MAGNETIC DASH MOUNT FOR PORTABLE MOBILE DEVICES MAGICMOUNT
http://www.ebay.com/itm/New-Scosche...519899?hash=item4402f7079b:g:amUAAOSwT-FZDL-J
This holds my Iphone 7, my phone plugs in and is within reach without distraction. NO MUSS NO Fuss and when my phone is off it is just a small metal block with a rubber face.
Ill get some pics later and post
mwittman77
Columbus, OH
17 Explorer Sport 4WD
Since this seems to be the general phone mount thread, just thought I'd share one I came across. Possibly the best I've found because its not device or vehicle specific, and can really hold tight without use of adhesives or clips. I'll take a pic later and share mine. https://www.breffo.com/products/breffo-spiderpodium
peterk9
Staff member
Moderator
Callsign
VE3
I realize this isn't your first post but I just wanted to say, Welcome to the Forum.:wave:
mwittman77
Columbus, OH
Here's an example of this mount in the vehicle. I didn't have a phone to put in for display purposes, as I was using mine to take the picture, but I've used this with several models of phones, as well as several different vehicles.
https://flic.kr/p/TGBcuZ
Thanks!
ou81
Ottawa, ON
2020 Explorer ST
I purchased a short Lightning cable to reduce the tangle and place my iPhone 7 Plus in the Sync compartment in front of the gear shifter. Having to open the compartment, grab the cable, plug it into the iPhone, stow the iPhone (the 7 plus only just fits) and then close the compartment is way too much work for me (I know... first world problem). I often find myself forgetting to remove the phone when I exit the vehicle since it's out of sight in the Sync compartment.
The Ford Explorer solutions for iPhones from proclipusa.com look promising because their mounts / holders incorporate the iPhone's Lightning cable. That is to say the Lightning cable (which you have to provide) clips into the holder so when you place your phone into the holder, you're also plugging in the lightning cable.
My problem is that they don't show you how to hide the cable to make for a clean installation.
ProClip uses both a mount and a holder. The mount attaches to your dash (or center console) and the holder attaches to the mount. You plug your phone into the holder which also has a clip for your cable.
Here's a link to the mount that attaches to the center vent on your dashboard (2016-2017 Ford Explorer):
http://www.proclipusa.com/dashboard-mounts/vehicle/ford/explorer/2016-2018/proclip-center-mount-855144-12946.cmsv?p_leftorright=0
You can attach their center mount product (specific to the 2016 - 2017 Explorer) to the center vents on the dashboard (no drilling required). Is it possible to run a lightning cable through the center dashboard vent and down into the Sync compartment? This would make for the clean (no unsightly wires) install I'm looking for. I'm happy to pay a pro (or my dealer if they can do it).
Thanks for any advice on the subject.
reserved50
2013 Sport Exploder
if you already have a suction cup mount and they didn't give you an adhesive disk, you can convert it to mount anywhere by using a pad with adhesive tape on it. Just make sure you measure the suction cup when in use since the surface area is larger. I would clean the area before using with a mild detergent and wipe dry if they didn't include a cleaning wipe, using solvents such as nail polish remover WILL melt the plastic:rolleyes:
https://www.amazon.com/s/ref=sr_st_price-asc-rank?keywords=adhesive+mounting+disk&rh=n:15684181,k:adhesive+mounting+disk&qid=1497253457&sort=price-asc-rank
DanF861
Minneapolis, MN
2017 Explorer Sport
I'm curious how people mount their cell phones in their Explorers. Would love to see some pics/ideas, especially from anyone with an iPhone X and if you can utilize wireless charging in the car...
thefranchise713
Buffalo, NY
'18 Toyota Prius Prime
I have an Arkin cell phone mount, I use the vent mount and it sits on the left side driver's air vent. I ran a long USB cable underneath the panels, under the dash, and up the side to the phone.
expoman55
Location
Upstate NY
Upstate NY
2015 Explorer Sport
magnetic mount on my dash next to vent.. my cell has a very thin metal plate inside back of case ...
Love it have it in plain sight so it is functional without taking eyes off road.
DanF861
Minneapolis, MN
2017 Explorer Sport
I’ll probably end up doing something like this. Are you using an adhesive magnetic mount?
SlowPaleGuy
WV
2015 Ford Explorer XLT
Did you end up running thecable through the dashboard to the Sync compartment? I'm thinking of doing the same thing
