zee1b
- May 22, 2010
- Central, Florida
- 1996 Eddie Bauer 5.0 2wd
Hi Ya'll,
Need to give you the history first, 6 months ago we installed a new fuel pump (complete), fuel filter, and did a full tune-up on the engine, the x had been sitting for over a year before i purchased it.
Saturday about 10 miniutes from my house it felt as if the ignition cut off (twice within a few seconds) then it just stopped running all together.
When going to start it it would just try to start (start and stall).
We towed the x home and after about 1/2 hour it started up but only stayed running for about 5 min. If engine is cold it will run for 10miniutes then may idle erratic for a few sec. then stalls and will only start for approx 1 second every time you turn key over.
Lastnight i installed another fuel pump because a friend of mine came over with a matco code reader and it said primary and secondary fuel pump circut. He said that the pump had gone out again. I was so damn happy because the truck ran for about 10miniutes then it happened again it stalled out. I didnt go to work today because of no way to get there (not a good thing). The code that it is bringing up is CODE 556 and at the end i get the 111. It it the fuel pump or the fuel pump relay circut that is 556 and where do i go from here to get my x back on the street. Any and all help will be appreciated.
I had forgot to mention that we did replace the fuel pump relay also,
Thanking You in Advance,
Chuck zee1b@aol.com
Chuck zee1b@aol.com
