nothinbutroad
- April 29, 2012
- Grand Terrace
- 1991 ford explorer
so im having some real trouble figuereing whats wrong with my explorer. during a koeo test i get a code 22. but during the koer test i get the codes 12, 13, 21, 32, 64, i used to get a 66 but i replaced my MAF so i no longer get that code. i have also replaced the O2 sensor. when i start her up she runs normal for a little while.... then i hear popping from what sounds like the cat/con, then dies 30sec-1min into idle( i cant even complete the koer test before it stalls) i noticed that i started having problems after i replaced my alternator, rough idle, stalls, black smoke, my volts drop, and spike, never steady, i also noticed most of the codes i get says the signal voltage is too low, i had the alternator tested, its all good. ive been messing with this truck for weeks, im out of ideas of where else i should look, replace, etc. im looking at replacing the map sensor, but idk if that would help at all, im pretty sure im trying to fix multiple problems.
