Conflicting warranty info
flip4prez
2012 explorer xlt fwd
Signed up for an answer to some conflicting warranty information. Here goes. Is the wheel bearings covered under the 7/100k mile certified pre-owned limited powertrain warranty. Ford has a brochure on their website that says it is. But i called ford and they said it isn't. So which one is it?
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Only the bold items are covered under the 7yr/100k. Wheel bearings are not in bold there fore only covered under the 12mo/12k warranty.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
But wouldn't they still be covered under the original 5 year, 60k Power Train warranty if that was still in effect?
flip4prez
Under front wheel drive front and rear wheel bearings are in bold. In my case i have 64500miles on a 2012 xlt fwd
flip4prez
Heres a closer screenshot looks bold to me
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Yup, you are right. Sorry, was trying to make it out on my cell in the first image which was blurry. You should be all covered.
flip4prez
Its all good sorry first picture was blurry.
I called ford and they said the bearings are not covered. Wanted to make sure I didnt have to pay for a warranted item or if anyone had them replaced under the cpo 7yr/100k miles powertrain limited warranty. Wondering why they are saying something is not covered when it states it in the brochure.
reserved50
2013 Sport Exploder
a lot of service people are monkey see monkey do, if they have never experienced it before it probably isn't possible till you find one that takes initiative and isn't just counting the hours to go home. Trick is to ask to talk to a manager, if you know you are right and they have the same poor attitude you had with the previous person you need to avoid that dealership. You can also try and guide them and show them the light if you're stubborn.:hammer:
ECinEI
2015 Explorer Sport
I addition to the '15 Sport my wife drives I own an '09 Sport Trac that I bought as a CPO vehicle in 2012. I had both front wheel bearing replaced under the CPO warranty for a $100 deductible. Only one was making noise but the shop replaced both stating the other was "just as old". My second best auto repair experience ever. The first involved a Lexus dealer. When you say you "called" Ford do you mean Ford Corp, or a local dealer? I'd bring the car in with a copy of the CPO warranty and talk with the service manger of your dealer.
K Conflicting information? Stock 2011 - 2019 Ford Explorer Discussion 9
M ESP Warranty - vehicle miles Stock 2011 - 2019 Ford Explorer Discussion 2
C Preventive water pump replacement or extended warranty Stock 2011 - 2019 Ford Explorer Discussion 6
T PTU issues covered with ESP Warranty? Stock 2011 - 2019 Ford Explorer Discussion 3
B Salvage Title Warranty? Stock 2011 - 2019 Ford Explorer Discussion 5
0 Motorcraft warranty Stock 2011 - 2019 Ford Explorer Discussion 3
J Transmission leak not covered under 5 yr/50,000 powertrain warranty?! Stock 2011 - 2019 Ford Explorer Discussion 22
T Center wheel cap finish bubbling- warranty item? Stock 2011 - 2019 Ford Explorer Discussion 4
S Warranty on Ford Battery? 2016 Exp Sport Stock 2011 - 2019 Ford Explorer Discussion 34
A Ford Extended Warranty Stock 2011 - 2019 Ford Explorer Discussion 4
O Ford Dealer doesn't want to cover warranty :( Stock 2011 - 2019 Ford Explorer Discussion 30
J What Is It With Dealers and Warranty Work Stock 2011 - 2019 Ford Explorer Discussion 1
M Ford ESP Warranty or Not? Stock 2011 - 2019 Ford Explorer Discussion 7
S Recall and warranty quesiton Stock 2011 - 2019 Ford Explorer Discussion 4
K Stiff-armed by the dealer on a warranty issue Stock 2011 - 2019 Ford Explorer Discussion 43
L The Value of the Ford ESP Extended Warranty Stock 2011 - 2019 Ford Explorer Discussion 9
M Bringing vehicle in for warranty work Stock 2011 - 2019 Ford Explorer Discussion 7
D Tuner vs Warranty? Stock 2011 - 2019 Ford Explorer Discussion 1
J warranty question... Stock 2011 - 2019 Ford Explorer Discussion 10
M 2011 limited stretched timing chain, weeks out of warranty. Stock 2011 - 2019 Ford Explorer Discussion 8
S CPO Warranty question Stock 2011 - 2019 Ford Explorer Discussion 3
N Warranty Expiration Intentional from Ford Service? Stock 2011 - 2019 Ford Explorer Discussion 4
K Powertrain Warranty... Stock 2011 - 2019 Ford Explorer Discussion 1
DeLeSaAZ Does tinkering/adding this/that affect warranty OR ESP? Stock 2011 - 2019 Ford Explorer Discussion 8
A My sport is in the dealership for warranty work for vacuum leak. Rental? Stock 2011 - 2019 Ford Explorer Discussion 18
K Warranty Question.... Stock 2011 - 2019 Ford Explorer Discussion 14
D Good warranty service Stock 2011 - 2019 Ford Explorer Discussion 3
F First warranty repair, A/C pressure tranducer Stock 2011 - 2019 Ford Explorer Discussion 8
E Will Ford reimburse for parts if you replace yourself? (Warranty) Stock 2011 - 2019 Ford Explorer Discussion 12
W Warranty Start Date Stock 2011 - 2019 Ford Explorer Discussion 14
K Leather Seats and Warranty Stock 2011 - 2019 Ford Explorer Discussion 9
P Warranty Issues Stock 2011 - 2019 Ford Explorer Discussion 7
P Instrument Cluster Crack/ Warranty Issue Stock 2011 - 2019 Ford Explorer Discussion 20
C Warranty question Stock 2011 - 2019 Ford Explorer Discussion 14
J What warranty can I get? Stock 2011 - 2019 Ford Explorer Discussion 1
mrnavy2 Warranty Information Stock 2011 - 2019 Ford Explorer Discussion 7
D Simple warranty job now going on it's fourth day! Stock 2011 - 2019 Ford Explorer Discussion 10
W My factory warranty is expiring, please help! Stock 2011 - 2019 Ford Explorer Discussion 4
D Extended Warranty Calls Stock 2011 - 2019 Ford Explorer Discussion 8
J dealer refuse warranty on broken wheel stud Stock 2011 - 2019 Ford Explorer Discussion 22
J Is an Extended warranty (ESP) worth it? Stock 2011 - 2019 Ford Explorer Discussion 61
B Rust Warranty Stock 2011 - 2019 Ford Explorer Discussion 14
J Are TSB's not covered after warranty has expired? Stock 2011 - 2019 Ford Explorer Discussion 12
B Warranty Transfer Stock 2011 - 2019 Ford Explorer Discussion 5
T 60 Month Road Side Assistance Warranty Stock 2011 - 2019 Ford Explorer Discussion 2
A Paint issues and tiny dings. Warranty? Stock 2011 - 2019 Ford Explorer Discussion 2
H Tire warranty? 9k miles and a slit sidewall! (Pic) Stock 2011 - 2019 Ford Explorer Discussion 28
S Ford refuses to honor warranty Stock 2011 - 2019 Ford Explorer Discussion 22
D Prices To Extend the CPO Warranty? Stock 2011 - 2019 Ford Explorer Discussion 10
1 Hankook Optimo H246 warranty claim? Stock 2011 - 2019 Ford Explorer Discussion 10
Similar threads
