- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Thats awesome
I have a custom machined Dana 44 outer shaft on that side, to make up for th eadditional track width we built into the beams, it allows me to run the spring inside the slip yoke and it works perfect as long as the dust cap is tack welded in place it has held up just fine.
I will likely be running a setup more similar to yours with the next set of beams I build (less cut and turn, 4.5" wider per side, ball joint re-location, and dana 44 outers)
My ARB locker does not have provisions for the c clip retainer so a spring in the slip yoke is my only option
