Jeff213
- March 25, 2015
- Stockton, California
- 98 mounty 5.0 4x4
- Callsign
- KM6BVN
So I have had a crack in my drivers side torque monster for a while and its been getting worse and worse. I pulled it off, looked at it, thought i could weld it up. It was cracked on the outside.
I welded up the crack on the outside and it turned out that the crack went all the way through the collector inside where there isnt much access. I tried to weld it up with a stick welder and stainless rods, ended up blowing holes in it, and just started dumping metal in until the whole collector was filled up with metal.
Turns out putting that much heat into a header warps the hell out of it. It is a lot easier to weld on thick metal than on thin exhaust tubing..
I ordered a drivers side factory exhaust manifold for now to throw on and get the truck going again but I am now looking for either a torque monster or obx drivers side header if anyone has one laying around..
