Torque monster headers leaking collector
AWD96spoon
Ardmore, ok
1996, Explorer AWD
So I installed some torque monsters last weekend and have been battling a leak at the collector on the driver side. I had originlly tightened the flair down on the collector out of square which cause a huge leak. I loosened the bolts and squared it up and tightened the bolts back up and the leak was significantly reduced but still there, I let the system heat up and then tightened them again but it didn' fix it. This weekend I took it to a muffler shop to have a new exhaust run and had him check it out. He said that he pulled it off and nothing was deformed that he could see and he reinstalled it square and had me tighten then bolts again when I got home wen the motor was hot but it' still leaking. My question is, is there any kind of gasket I can put in there to seal this leak or should I go a different route?
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
AWD96spoon
Ardmore, ok
1996, Explorer AWD
Tried that this afternoon, no luck. It' leakinng right in the middle of the two bolts, not to one side or the other. Would RTV hold you think if I put it on the inside of the flared piece and then tightened it town and let it set up?
Turdle
Habla tortuga
Staff member
Moderator
Humboldt, KS
2000 Mounty
Ultra copper might-
It could be the down pipe flange has become oval instead of round. This will happen if one side get tightened down too far.
You might be able to bend it back to a rounder shape with a large channel lock pliers, using a tennis ball as a guide.
AWD96spoon
Ardmore, ok
1996, Explorer AWD
Turdle, I can't see any ovalness to it with just my eye, I'll put a tennis ball in it and see if I can tell but off not I'm gonna proba my put ultra copper or RTV on it.
Turdle
Habla tortuga
Staff member
Moderator
Humboldt, KS
2000 Mounty
RTV will just burn out, your onloy hope is the high temp copper RTV . Expect that joint to see 1000 degrees.
You will not be able to "see" a deformation that will allow exhaust gasses to leak. Use something round like a ball as a guide, lay it into the downpipe flange and this might make any deformation appear. Then, squeeze the "high" sides with big pliers. I had to do this once with good results. Just a dab will do ya.
AWD96spoon
Ardmore, ok
1996, Explorer AWD
Okay, I may take it to a muffler shop and have then flare me a new piece and weld it in there, I just had a new exhaust put on and they replaced everything but the flare and the down pipe even though I asked them to, and when I asked about it when it was done he said nothing was wrong with it. Gonna take it to a different shop now. I don' trust myself to be able to bend it jus enough to fix it and not cause leaks on other spots.
AWD96spoon
Ardmore, ok
1996, Explorer AWD
Well I ended up paying to have my new exhaust re made and new flared down pipes. It fixed the leak and sounds great! Thank for the help guys, this site is a life saver.
M Torque monster headers horsepower Modified 1995-2001 Explorers 8
Dono Torque Monster Headers with Bob back Modified 1995-2001 Explorers 10
A 5.0 Headers problems with Torque Monster and OBX Modified 1995-2001 Explorers 2
S Torque Monster Headers Modified 1995-2001 Explorers 6
B Torque Monster Headers in way of Camber/Castor Bolt! Modified 1995-2001 Explorers 7
B Torque Monster headers Modified 1995-2001 Explorers 11
9 Torque Monster headers making comeback ??? Modified 1995-2001 Explorers 91
A 5.0 Torque Monster Headers on eBay Modified 1995-2001 Explorers 5
P Torque monster headers Modified 1995-2001 Explorers 8
S Torque Monster Headers WTB Modified 1995-2001 Explorers 0
M Rusty Torque Monster Headers Modified 1995-2001 Explorers 20
B Torque Monster headers install problems Modified 1995-2001 Explorers 42
B Are 5.0/Torque Monster Headers still made? Modified 1995-2001 Explorers 8
R Do Torque Monster Headers increase the engine sound much? Modified 1995-2001 Explorers 1
S TORQUE MONSTER Headers GROUP BUY Modified 1995-2001 Explorers 652
X Wanted Torque Monster Headers? Modified 1995-2001 Explorers 2
M anyone know whats up with torque monster headers Modified 1995-2001 Explorers 9
P Torque Monster Headers installed CODE PO300 Modified 1995-2001 Explorers 10
1 torque monster headers.... Modified 1995-2001 Explorers 17
D Torque Monster Headers and 1" Intake Heat Spacer Installed Modified 1995-2001 Explorers 0
V Torque Monster Headers are awesome Modified 1995-2001 Explorers 33
S Getting Torque Monster Headers, what else should I do? Modified 1995-2001 Explorers 3
C Installed Torque Monster headers and spacer, now I have a lopeing or chugging idle Modified 1995-2001 Explorers 2
Hyper26414 Torque monster headers vs. Ford racing headers Modified 1995-2001 Explorers 5
MountaineerGreen Torque Monster Headers Install Write-up and Review Modified 1995-2001 Explorers 364
S guys with torque monster headers ? Modified 1995-2001 Explorers 5
W Torque Monster Headers Ordered!! Modified 1995-2001 Explorers 17
S Nice bit on Torque Monster Headers on Trucks! Modified 1995-2001 Explorers 1
B Torque Monster Headers First Impressions Modified 1995-2001 Explorers 3
LiKuiD So my Torque Monster headers are installed... Modified 1995-2001 Explorers 19
S Torque monster help Modified 1995-2001 Explorers 1
1 Christmas Came Early... Torque Monster!!! Modified 1995-2001 Explorers 4
Dono torque monster install gone bad Modified 1995-2001 Explorers 34
P torque monster header install dvd link Modified 1995-2001 Explorers 0
P torque monster install gone bad.. Modified 1995-2001 Explorers 19
M (HELP!) Torque Monster Header custom EGR pipe Modified 1995-2001 Explorers 4
P Torque Monster header availability teaser... Modified 1995-2001 Explorers 33
C torque monster header not running right Modified 1995-2001 Explorers 9
celly Torque Monster Header (TMH) Gasket Replacement-Pointers needed Modified 1995-2001 Explorers 94
Cobraguy Torque Monster Header Installation Tip Modified 1995-2001 Explorers 1
1 Torque Monster and front cats? Modified 1995-2001 Explorers 12
Mutineer Mutineer Torque Monster Install Modified 1995-2001 Explorers 16
W 1 of 2 Torque Monster header(s) install Modified 1995-2001 Explorers 2
S torque monster header owners ??? Modified 1995-2001 Explorers 8
T 98 explorer suspension torque spec. Modified 1995-2001 Explorers 4
S Torque Monsters Modified 1995-2001 Explorers 12
K torque converter not unlocking. Modified 1995-2001 Explorers 2
bigred4x4 torque converter solenoid Modified 1995-2001 Explorers 4
M Looking for Torque Mods Modified 1995-2001 Explorers 4
C 1999 explorer sohc torque converter lock up Modified 1995-2001 Explorers 13
Similar threads
