Custom Explorer Chassis
slammedxonair
vermilion ohio
91 xlt 2wd
Thanks guys the rearend is kinda based off the Jaguar suspension with no UCA, I still have some adjustments to make on the lower arms to gain some negative camber but basically the shafts are locked into place and also act as the upper arm. We were originally going to use a mark viii / thunderbird rearend but the owner wanted to go this route instead. So thats what we did.
As for the body I'm not touching it at all just building the frame, doing the air ride and sending it back to the motor shop in Indy. They are doing the motor, tranny mounts a few other things and building the body mounts on the truck.
Heres the Heidts rear setup
http://www.heidts.com/index.cfm/pag...ategory_id=84/home_id=70/mode=prod/prd130.htm
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
How do you adjust camber in the rear?
Posted via Mobile Device
slammedxonair
vermilion ohio
91 xlt 2wd
lower control arms are threaded and adjustable at the bushings under the 3rd member. They are all the way in right now, so I need to crank them out some to gain some more negative camber.
99SportX
Duluth, MN
1999 Ex & Mounty
Awesome man. That is so cool.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
Better and better, will you add skid plates, or be able to lift the tires?
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
I see, the LCU's were made to fit to the as delivered rearend. How much trouble would it be to shorten those LCU's, and make the mounting points outboard a few inches?
slammedxonair
vermilion ohio
91 xlt 2wd
Well it would need a whole subframe built to support the arms, but changing the mounting points and shortening the arms would probably cause more positive camber and the possability of the ujoints binding. Nothing is going to get plated becaues I highly doubt hes going to drag this truck after everything he has into it.
Drag block brackets could allways be built into it if he decides so before I send it back to indy. What do you mean by lift the wheels? Do you mean like 3 wheel or hop or soemthing? i highly doubt it will do either once of those since the suspension is being setup more less to handle the 500 hp rather than do lowrider type stuff. He might be able to get it to do a small 3 wheel around a corner but will probably destroy the body kit in the process.
mounty71
It's green, not gray.
Oakland, CA
'00 Mountaineer
The fact that this thing is being built with "show" AND "go" in mind is very cool. And the fabrication looks great! Make sure the owner sends some pictures to you to post up here after you return the frame to him.
slammedxonair
vermilion ohio
91 xlt 2wd
yea I'm hoping the motor shop and other shops involved will keep sending me pics so I can update these threads for him. This is on various sites I frequent and sponsor.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
For suspension geometry, if each axle is say 18" long, and the LCA's are 22" long, the camber will change with the ride height. That's good for handling in the front etc, but not ideal for a vehicle that has big ride height changes.
I understand that the center section has mounting ears made for the LCA, that's great. But if a tiny subframe was made there to extend those points out the 2-3 inches that would allow shorter LCA's, then the geometry would be better. I'm not suggesting doing away with the adjustability. Leave that in there, setting the camber is different. If you make the camber right with equal length LCA's to match the axles, then the camber stays the same at all ride heights.
For lifting a wheel, I just wondered what would happen if the frame lays on the ground, and more air comes out of the bags? Just curious about that, you have the frame so low that it could rest on the ground and have the weight off of the tires.
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
Camber changes shouldnt be that bad because the pivot points on the other end (near the wheel) arent vertical from each other - the LCA ends before the U-joint's cap center.
As for lifting a wheel: thats pretty much impossible - in order to lift a wheel off the ground with pneumatic, you'd need a double-acting pneumatic (or hydraulic) cylidner, not air bags. The air compressor is a positive pressure unit - it does not create a vacuum and even if it did, it would need to create enough vacuum to lift the wheel/tire combo (which is probably impossible).
slammedxonair
vermilion ohio
91 xlt 2wd
yea you would have to use air cylinders, 2 air bags or a limit strap of sorts. The bags will be setup 100% compressed when the frame touches the ground.
slammedxonair
vermilion ohio
91 xlt 2wd
Hello everyone. Here is a quick update I've been pretty busy lately and haven't taken many pics, but so far half of the welds on the frame are ground down and I got the shear load gussets ready to go.
Kentucky
wow dude. I normally dont like these types of rides but that thing is winning me over! lol
you got my respect. that is some SERIOUS nice work! :thumbsup:
do you have a cnc plasma machine to cut out stuff?
slammedxonair
vermilion ohio
91 xlt 2wd
Thanks for the comment. And yes I do have a CNC plasma system. It's a Dynatorch system with a Hypertherm 1250 plasma. It's an industrial system with servo motors. Heres the pics I have from my old shop of it.
Heres a couple vids of it as well
http://www.youtube.com/watch?v=dERUwvZaiX4
http://www.youtube.com/watch?v=naKW4FOfAM4
This is when I first got it and before I put the cutting slats on it.
Some bag brackets I was making for my truck.
Kentucky
thats a nice set up there. I have used a plasmacam system at shop and i love cnc work.
how well do you like the Hypertherm 1250? I herd they are the best out there. that and thermal dynamics.
to anyone wondering.. miller sucks. thats what we use and it always cuts out randomly and its not because we have air in the line or bad ground, tips, cups etc. they just suck.
this is what i might get when I can find $17,000+ :p
http://www.youtube.com/watch?v=AdC9QbG6lj0&feature=related
what program do you run?
also. with all that frame/suspension work is that going to be street legal?
slammedxonair
vermilion ohio
91 xlt 2wd
Yea the Hypertherm 1250 in my opinion is the best single phase air plasma on the market, it also can be hooked up 3 phase as well. The software to run it is the dynatoch cutting program along with there premium package that includes the nesting and raster to vector software. I mainly use autocad 06 for doing designs though.
As for being street legal it probably depends on the state. Theres people all over the place that build trucks like this and even lower. My personal explorer lays the rockers flat on the ground. All of my receipts on everything I do is marked for show and off road use only, even know the air line fittings and other things are DOT approved.
The mission with this project was build a awsome looking chassis that lays on the ground, can handle 500hp, and will ride like a caddy.
C Lowering my 91 explorer Lowered Explorer - Ranger Suspension Tech 0
J Finally lowered my explorer! Lowered Explorer - Ranger Suspension Tech 30
S Body kit for a 2002 Explorer Sport? Lowered Explorer - Ranger Suspension Tech 0
B Lower explorer? Lowered Explorer - Ranger Suspension Tech 3
S Lowering 2000 explorer Lowered Explorer - Ranger Suspension Tech 2
P Best way to lower my explorer?? Lowered Explorer - Ranger Suspension Tech 0
B what i want my 03 Explorer to look like Lowered Explorer - Ranger Suspension Tech 0
N Lowering 04 Explorer 4x4 Wagon Lowered Explorer - Ranger Suspension Tech 4
1 What shocks are good for a lowered explorer Lowered Explorer - Ranger Suspension Tech 3
1 Airbagit.com kits??? Should i bag my explorer or my ranger? Lowered Explorer - Ranger Suspension Tech 0
L Lowering a 2007 Explorer Lowered Explorer - Ranger Suspension Tech 0
J 98 explorer sport lowering blocks question Lowered Explorer - Ranger Suspension Tech 1
C i want to lower my 92 explorer with 20inch rims but idont want the front to butterfly Lowered Explorer - Ranger Suspension Tech 1
9 I want to lower my Explorer. Lowered Explorer - Ranger Suspension Tech 3
C Best way to lower a 2000 Explorer? Lowered Explorer - Ranger Suspension Tech 7
E looking to lower a 02 explorer sport Lowered Explorer - Ranger Suspension Tech 2
J Lowering my Explorer. Lowered Explorer - Ranger Suspension Tech 6
2 Dropping an 01 Explorer Sport. Lowered Explorer - Ranger Suspension Tech 4
A Lowering Explorer Lowered Explorer - Ranger Suspension Tech 1
9 How do I lower my 1994 Eddie Bauer Explorer? Lowered Explorer - Ranger Suspension Tech 3
F I'm looking to drop my 94 Explorer Sport 2WD. Lowered Explorer - Ranger Suspension Tech 4
O Lowering my 99 Sport Explorer. Lowered Explorer - Ranger Suspension Tech 2
S Drop my Explorer. Lowered Explorer - Ranger Suspension Tech 8
R please help! lowering 06 explorer/mountaineer Lowered Explorer - Ranger Suspension Tech 4
X Explorer lower on 22s. Lowered Explorer - Ranger Suspension Tech 19
I Trying to lower my 93 explorer eddie bauer Lowered Explorer - Ranger Suspension Tech 3
T Bagged 2002 Ford explorer sport Lowered Explorer - Ranger Suspension Tech 0
D Lowering first Gen Explorer. Lowered Explorer - Ranger Suspension Tech 28
O Lowering 2003 Ford Explorer Sport 4WD Lowered Explorer - Ranger Suspension Tech 5
C Lower Explorer. Lowered Explorer - Ranger Suspension Tech 5
F Air Suspension -Slamming an Explorer- Lowered Explorer - Ranger Suspension Tech 26
R Drop on explorer/ranger? Lowered Explorer - Ranger Suspension Tech 3
S Is there a market for explorer control arms? Lowered Explorer - Ranger Suspension Tech 6
Turdle Lowering a 95-01 ( torsion bar front) explorer Lowered Explorer - Ranger Suspension Tech 8
A Keeping the 99 5.0 explorer. Going to mod it. Need some help Lowered Explorer - Ranger Suspension Tech 4
K questions about how to get the front end down further(lowered explorer) Lowered Explorer - Ranger Suspension Tech 4
M Eibach ProKit on 3rd Gen Explorer (2004) Lowered Explorer - Ranger Suspension Tech 5
C Lowering kit for 2000 4wd explorer limited? Lowered Explorer - Ranger Suspension Tech 6
I Bolt in notch for Explorer? Lowered Explorer - Ranger Suspension Tech 1
C The Lowest Explorer Pic Thread!!!! Lowered Explorer - Ranger Suspension Tech 115
R 91 explorer drop beams Lowered Explorer - Ranger Suspension Tech 5
oplitic How to: Install camber adjusters 2nd Gen Explorer - Fixing a lowered X's alignment Lowered Explorer - Ranger Suspension Tech 23
M Lowering my '99 Explorer Sport Lowered Explorer - Ranger Suspension Tech 1
B How to lower my 2001 Explorer Sport 2dr Lowered Explorer - Ranger Suspension Tech 7
J lowering kit for 91-94 explorer sport Lowered Explorer - Ranger Suspension Tech 7
B 92 explorer on 22's Lowered Explorer - Ranger Suspension Tech 10
E Lowering The Front Of A 2000 Explorer Lowered Explorer - Ranger Suspension Tech 1
S Lowering Kits for AWD Explorer? (was need help) Lowered Explorer - Ranger Suspension Tech 2
K new member--dropping my explorer Lowered Explorer - Ranger Suspension Tech 0
L Bag my Explorer? Lowered Explorer - Ranger Suspension Tech 3
Similar threads
