CHRISXPLOR
- May 4, 2008
- Chicago, IL
- '01 SPORT 4x4
help please!!!!
when i turn the wheel all the way to the left and turn into a pothole a always hear a clunk. is this do to a bad CV?![]()
it moves alittle at 9 and 3??? what can that be?![]()
nope...unless you've got an internal problem its pretty straight forward. . you might want to put a little lithium grease in the end just because...
Mountaineergreen you said"You may need to drive the bolt out with a punch or screwdriver, the punch being recommended".) So this bolt is not screw thru the knuckle?,is just tite press meaning that I have to hit it to get it out? It look so tite that look that is screw rater than press.So do I hit it or screw it out.Please reply,thanks!
Thanks for reply,I been trying but is like seal it there,I spray it with pb blaster spray,and still no improove. I will let it set for tonight and try tomorrow.If any other sujestion let please let me know.
