- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Where did you put the Mercon ATF, and was it ATF or Mercon, or Mercon V?
The differential takes the grease(75/90(or 110 etc(depends on towing option))), don't put ATF in that. The front axles go into the diff, the transfer case is behind the transmission. The Mercon V goes into the transfer case on the back of the TC, where the rear driveshaft comes out of it. There are two large plugs, labeled "FILL" and "DRAIN".
If you put ATF into the diff, then you need to get that out, using a suction pump is best. Welcome,
