BK_89iX
- November 26, 2004
- CA
- '97 SOHC
I need some help tracking down a subtle "rumbling" that seems to be coming from the right front. It started about a year ago and very gradually it has gotten louder. It's most apparent at about 20-30mph, but it is present at all speeds, loads, etc. Vehicle is a '97 Explorer AWD SOHC with about 90k miles.
Here are some of the steps I've taken:
- Spent many hours here with the search button.
- Tires are pretty worn, so I swapped them front to rear. No change.
- Changed out the transfer case fluid. Nothing unusual noted.
- The noise seemed to diminish turning right or left at 40-50mph, so I suspected the wheel bearing/hub. Swapped both sides out for new ones yesterday, but unfortunately no improvement.
- While I was in there, I took a good look at the pads/rotors/calipers. That all looks good.
- I also had a good look at the half-shafts. All the CV boots are intact. However, on the right side, the CV shaft felt a bit notchy or unsmooth when I rotated it by hand. The left side felt very smooth by comparison, but of course it also rotates the front driveshaft, so maybe it's an unfair comparison due to the increased force/load required to rotate this side by hand.
So here is the question, am I on to something with the "feel" of the right CV shaft? Could this be the source of my noises? Are CV joints known to fail if the boots are still intact? There are no traditional symptoms like clicking or popping or something happening when pulling away from a stop and turning left or right.
Anything else I should be looking at before I throw more parts at it?
Thanks!
BK
Thanks!
BK
