The tally sheet so far...
Here's who's going so far...
THE DESERT OUTLAW
DESERT DAN
THUNDERHORSE
JOSH S.
MARK MEENAHAN
& maybe DB-1? [I haven't heard from him, but on the last run, he had a good time. He bent his tie-rod, so, let's cross his fingers he's still allowed to 4 wheel his Ranger!]
To answer CoolChrisCush's question,
4 Hi? Well, it all depends on your gear ratio and transmission type. If you have an automatic running in 1st gear w/4.10 or 4.56 gears, you should do alright out there. If you have 3.73 or 3.54 gears and a manual or an automatic, then, I'm thinking this might not work. You will be using your brakes entirely too much out there, and brake failure could spell
DISASTER!
As for CoolChrisCush's body lift/33" tire setup...
You'll be fine out there with the clearance your 33" tires will give you. Not a problem in the least. Check to see that your 33" tires are not rubbing the fenderwells. I'm just not sure about your ability to crawl up those rutted, rocky roads without burning up a clutch or driving too fast for the conditions, that's all...
