z0rbadelic
- September 4, 2014
- Location
- New Jersey
- 2013 Explorer Limited
- Callsign
- KG4JYA
Hello All,
I just recently purchased a 2013 Ford Explorer Limited with the 3.5l V6 engine. The vehicle has a class III aftermarket hitch attached under the rear bumper, however there is NOT a “TOW” button under the headlamp switch, and no engine oil cooler. My questions are focused around towing. I would like to eventually tow a travel trailer ranging between 2500-4000lbs (not yet purchased).
I noticed in another thread that a gentleman with a 2013 Explorer Sport merely installed a TOW switch on his own and everything seemed to work. Would this be possible with my Limited Edition Explorer? Is the software already in the vehicle to support this? There are already accessible options for Trailer Anti-Sway, this leads me to believe that the software is present. I believe I would need to purchase the button assembly, panel that would fit the buttons, and possibly a wiring harness (not sure of this)?
Regardless of if I could install the “TOW” button myself, I think I would still need an engine oil cooler. So a few questions on this.
Thank you all in advance
Mike T.
- I believe the OEM engine oil cooler is a plate cooler in that it uses the engine’s cooling system to remove heat from the oil. Would this still work with the radiator I have or would I need a larger one with more cooling capacity? (I really do not want to swap out a radiator) How do I know which radiator I have? Also is there a diagram somewhere that shows where to patch in the engine oil cooler into the cooling system?
- I noticed that there are quite a few aftermarket engine oil coolers that merely screw onto the oil filter receptor and then move the oil into a radiator of its own. If I were to go this route how adversely would it affect engine performance starting and running on cold days in the north east?
Mike T.
