2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
I haven't accomplished anything the past 7 days due to what I thought was a heart attack but was actually an atrial fibrillation episode. I seem to be doing fine on blood thinner and heart rate medication so today I installed a newly purchased water pump.
It was part of a cooling kit from Auto Zone that includes a new fan clutch. I also started working on the fuel supply system. There are interference issues with the Aviator fuel pressure temperature sensor (FPTS) being installed on the Mach 1 intake manifold/billet fuel rails.
The body of the FPTS is wider than the space available. I was hoping to connect the FPTS pressure signal to a pulse width modulator (PWM) fuel pump controller to control the pressure of a high flow pump like I did on my 2000 Sport for the supercharger. Utilizing the available 90 degree adapter would probably result in the FPTS interfering with the valve cover.
I'll try cutting off the excess of the FPTS mounting plate next to the manifold and adding a spacer between the manifold and the fuel rail. Hopefully that would not impact the alignment of the injectors between the rail and the manifold enough for the injectors to leak. I've decided it will be too crowded in the front for a fuel hose there connecting the two rails.
