- December 28, 2010
- Russell, Ontario (Ottawa area)
- 2023 Aviator Reserve 201A
- Callsign
- VE3
I've never used the key blade so I'm not familiar with how much force is required to lock/unlock the door. Did you by any chance check to see if there was power going to the actuator when you had the door panel off? If there was power then that could be a good indication the actuator isn't working. If there was no power, then you have another problem. Just FYI; Search Results | Auto Nation Ford White Bear Lake
