koda2000
- September 2, 2011
- x
my daughter informed me that the driver's door window would not go down on her 2000 Mountaineer. of course i assumed that meant the switch or motor wasn't working. wrong. as it turns out the glass is somehow stuck in the full up position. the motor and switch work fine, but the glass has pulled out of the track. she told me her boyfriend pushed the glass up by hand because it wouldn't go up straight... hmmm, not sure what that means.
1. what's holding the glass up? out of the track i would think it would just drop, but i couldn't even pull it down with my hands.
2. how do i reattach it to the track? i can get the glass on the track easily enough, but it will have to be glued in with something and if the glass is somehow stuck in the door frame it will just pull out again when you try to roll the window down. i didn't have much time to play with it today. i just don't what the glass to suddenly drop, so i raised the track and told her not to put it down.
