Make sure it is very clean. Maybe run a wire wheel or sandpaper on the metal and some alcohol.
Darn. And from what I've been told silicone is pretty much a one shot application, will need to remove and re-clean if you want to apply more.
I just put the high mileage oil in and curious to see if it will help (it did in a previous car I had years ago with seeping leaks) but this one is in the oil pan so it's different.
I'm debating if I should just leave it for the time being and see how much oil I lose in a week and see how long the red silicone holds up for.
Or just pay my mech the $850cdn he quoted me to take off the balancer, wire brush everything and clean everything extremely well including the oil pan and time cover gasket area and re-seal the cracks and the timing cover gasket area and replace the crankshaft seal and balancer and get it over with. The crankshaft seal is just seeping, the high mileage oil may be able to stop this. He did mention about the bushings up front (in the centre right below the motor) and how they will wear quicker from the oil. Which bushings are these? Hope not control arm.
Since both my valve cover gaskets and the timing cover gasket were leaking prior to this big repair, from the looks of it, the oil was coming down from the same area and down to the same area, so this extra wear on those bushings has already been happening for the past 2 years since I got the truck.
Before the silicone application, the oil was literally coming out of the cracks at a very fast rate like hot syrup and it would come out right away. Clean up all the oil, start the car and oil is flowing out within a second. I would get fast drops to the floor and about 2-3 drops every 1-2 seconds. Right now after the silicone, it is just seeping. I just ran the truck while hot and watched under it for a full 5 minutes and I didn't see a single drop come down.
But my mechanic is right, to really clean and access that area, the balancer and belt unfortunately need to come out first. You are just too limited in how close you can get to the area without removing them and you would have to clean and apply everything with a brush.
