early style overhead console fix? | Ford Explorer Forums
Texan01
Dallas, TX
1995 Explorer XLT
Ok, so my early style Overhead Console has started fritzing out, figured it was the module itself so I pulled two from the yard and swapped them in. no change.
It acts like its losing power somewhere down the line from the roof itself. Does anyone know where there are other connectors to check to see if theyve worked themselves loose? It's an intermittent and will cause it to reset like you first turned the key on, really annoying at night when it doesn't respect the lights on signal at first so it is really bright before it dims.
