grandpax2
- July 25, 2008
- '95 xlt
AFTER REPLACING THE UPPER AND LOWER INTAKE MANIFOLD GASKETS, I FOUND THAT I HAD NOT CORRECTLY INSERTED THE EGR TUBE BACK INTO THE INTAKE MANIFOLD. I HAD A MASSIVE VACUUM LEAK. THE ENGINE WOULD ONLY RUN AT HIGHER RPM AND DIED WHENEVER THE THROTTLE WAS BACKED OFF. I HAVE TEMPORARILLY BLOCKED THE VACUUM LEAK, WHICH IS ON THE ENGINE SIDE OF THE EGR TUBE.
HOW CAN A MOVE THE EGR TUBE UP INTO THE INTAKE MANIFOLD? THANKS
