Gator Jeff
Elite In Memoriam
- December 11, 2004
- 2000 Sport 4x4
This is a recap of my previous posts, but things have quickly worsened as you will soon read. While driving yesterday, my battery light came on and the volt gauge was reading low. It happened at highway speeds and after driving for about 15 minutes. The light went out and the gauge returned to normal.
Quick background... 2000 Sport with the OHV engine, 126,000 miles, Northeast truck since new, 1 year old Bosch battery with about 10,000 miles on it, original alternator and cables.
I took it to Pep Boys and they ran a diagnostic and said that nothing was wrong. They also didn't get the light or gauge. Well, when I started her up to drive home, I got the light and gauge issue again. I went back in and basically said WTF, although nicely and they said to just get a new battery since it's under warranty.
It started fine this morning, but the light and gauge issue was still present.
Needless to say, I'm not 100% confident about their diagnosis now. So, a few questions.
1. What are the odds that the alternator is bad even though it passed the diagnostic?
2. If I need a new alternator, should I go new or remanufactured? Also, 95 or 130 amps?
3. Could it be the cables? I'm tempted to change them out anyway since the clamps seem super thin.
4. Is there another potential issue that I and they did not think of?
Started fine this evening, but idled very rough for the first 10-15 seconds. Ran great after that. Smooth idle at stop lights and strong acceleration. Had to make a stop and it started fine once again. Also, headlights might be slightly dim. Battery light and sagging gauge present the whole time. All other electrical (radio, gauges, etc.) work just fine.
Going home from the firehouse and the radio blinked off for a moment. Then as I was nearing home (thank God!) my ABS light came on, then the truck started to lag a little bit and then the tach stopped working. The radio also blinked on and off several times. My headlights stayed on as did my instrument lights, but the reading lamps did not work. Also, the power locks were still working.
A fellow firefighter convinced me to avoid PepBoys, not hard after reading the above and replacing the stuff myself. I have no problem trying that, but is there anything that I should consider other than the new battery, alternator and cables?
HEELLLLPPPPP!:roll:
HEELLLLPPPPP!:roll:
