Martin Rowe Jr.
Philadelphia, PA
2013 Limited 3.5L
Hey guys, first time poster here. I have a 2013 Limited and have recently upgraded to LED head and fog lights, from a previous HID upgrade. Now I've gotten the itch to swap out my front and rear turn signals and upgrade them to LED as well. I'm wondering if anyone here has done it, and if so, I'm seeing some things online that are saying it's possible to swap out my stock flasher to an electronic flasher (instead of wiring resistors in line) to avoid getting a hyperflash. Can anyone help me with some info please? Thanks.
sheltonfilms
Hoover, AL
2013 Limited 3.5L
Flasher system is built into the Body control module. Older style vehicles before smart junction boxes. Like old Rangers and Explorers used physical flasher relays.
I think @jmr061 was working on this. I think he may have found out that the Body control module had to be programmed to correct this.
Martin Rowe Jr.
Philadelphia, PA
2013 Limited 3.5L
Hmm, ok. I see that I can wire resistors into the actual harness, and I'm not necessarily opposed to doing that, I'd just prefer not to if it's possible. Hopefully @jmr061 can shed some light. Thanks for the response!
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum.:wave:
Martin Rowe Jr.
Philadelphia, PA
2013 Limited 3.5L
Thank you, I'm happy to have found it. I've been reading through a lot so far and there seems to be a lot of knowledgeable and helpful people. Hopefully I'll be able to contribute as well.
thefranchise713
Buffalo, NY
'18 Toyota Prius Prime
Yes, @jmr061 can help.
I run LEDs in all four signal bulbs in my Explorer, no resistors, simple BCM reprogram.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Can you explain what a BCM reprogram is?
Body Control Module. pretty much everything now is run through a computer now and resistors won't solve your problem.
I know on the superdutys there is an option that can be changed to turn off the fast blink.. it is all programming now.
Martin Rowe Jr.
Philadelphia, PA
2013 Limited 3.5L
Makes sense. I'm curious if this is something I can do.
PlatinumOwner
2016 Explorer Platinum
You'll need to change a setting on the BCM with FORScan if you don't add a resistor. You'll need a USB ELM327 and a Windows PC to do this. Front Lamp Outage detection is at BCM location 726-27-01. Rear Lamp Outage Detection is at 726-27-02.
I'm not sure what the settings are on the Exporer as I haven't tested them yet and the settings on the F-150 change the concurrent light setting on my '16 Explorer so I'm guessing they are not the same.
Here are some sites for more info:
http://forscan.org/
http://www.f150forum.com/f118/forscan-software-enable-disable-features-your-truck-348987/
613GT500
Ontario, Canada
2016 XC90 T8 R-Design
I can also confirm that @jmr061 findings will disable "light out" detection, aka hyperflash.
r1lukasz
17 explorer sport
Is there any update on explorer turn signal? Can some one please post how to disable outage detection
peterk9
Staff member
Moderator
Callsign
VE3
We
613GT500
Ontario, Canada
If you have access to an OBD reader (one that can read MS-CAN) along with the Forscan program, you can disable the light out detection.
1995E
Maryland
95 + 11 Ex both XLT
What's the exact values?
Also, if it helps, I found LED turn signal bulbs that don't activate the hyperflash. I can forward that link over.
613GT500
Ontario, Canada
Assuming you guys know how to use Forscan already, the following changes needs to be made in the following module.
BdyCM Module configuration (AS-BUILT FORMAT)
Look for the following values below and change the value accordingly (0=OFF, 1=ON)
726-27-01 x0xx xxxx xxxx Front Lamp Outage Detection Off
726-27-01 x1xx xxxx xxxx Front Lamp Outage Detection On
726-27-02 xxxx xxxx x0xx Rear Lamp Outage Detection Off
726-27-02 xxxx xxxx x1xx Rear Lamp Outage Detection On
r1lukasz
17 explorer sport
when I access values this is what they are stock brand new 2017 explorer sport
726-27-01 0100 0001 0057
726-27-02 0000 0000 0157
so I can change the front but rear looks like is already off? can someone confirm please
mbushnell
Location
Northern Front Range of CO
CO
2016 Ford Explorer Sport
So, in order to cure the hyper-flash if I decide to replace my turn signals with LED's, I will need to download either Bootcamp or Parallels to run on my MacBook Pro, get a copy of Windoze (that should tell you how happy I am about that...) download a copy of Forscan, and what else?
How does Forscan communicate with my 2016 Explorer Sport?
Mark
S Weird electronic issues Stock 2011 - 2019 Ford Explorer Discussion 11
F Electronic Steering Control Stock 2011 - 2019 Ford Explorer Discussion 4
G Turn signal flasher relay Stock 2011 - 2019 Ford Explorer Discussion 34
H New flasher issue in the heatwave Stock 2011 - 2019 Ford Explorer Discussion 14
C Flasher button, bad placement Stock 2011 - 2019 Ford Explorer Discussion 12
P 2017 Ford Explorer Limited drivers side LED fog light has quit working Stock 2011 - 2019 Ford Explorer Discussion 2
M License plate LED interference Stock 2011 - 2019 Ford Explorer Discussion 4
J Interior LED’s Stock 2011 - 2019 Ford Explorer Discussion 3
A 2016 Ford Exploer Sport LED Foglights Stock 2011 - 2019 Ford Explorer Discussion 2
B LED Rear Direction Bulb ? Stock 2011 - 2019 Ford Explorer Discussion 2
T 2014 Explorer XLT rear bumper led reflector light install Stock 2011 - 2019 Ford Explorer Discussion 7
J 2018 Ford Explorer LED bulbs Stock 2011 - 2019 Ford Explorer Discussion 9
B Teal LED flex strip? Stock 2011 - 2019 Ford Explorer Discussion 16
J Change in 2018 remote - no LED to indicate Remote Start Stock 2011 - 2019 Ford Explorer Discussion 16
TBill LED Back-up reverse lights Stock 2011 - 2019 Ford Explorer Discussion 24
D 2014 LED Cupholder Cleaning Stock 2011 - 2019 Ford Explorer Discussion 1
M 2018 Explorer Sport LED lights options Stock 2011 - 2019 Ford Explorer Discussion 14
L Does anyone make vehicle specific LED Light bar brackets for the Explorer? Stock 2011 - 2019 Ford Explorer Discussion 4
B 2016+ Base Model, Add LED Signature Lights? Stock 2011 - 2019 Ford Explorer Discussion 7
S License plate led camera interference Stock 2011 - 2019 Ford Explorer Discussion 11
N Switchback LED Halo Turnsignal/DRL Stock 2011 - 2019 Ford Explorer Discussion 1
E 2017 LED headlights question Stock 2011 - 2019 Ford Explorer Discussion 1
E Changing LED Signature Lights color Stock 2011 - 2019 Ford Explorer Discussion 5
N LED headlight out already Stock 2011 - 2019 Ford Explorer Discussion 39
F LED Fog Lamps standard on platinum? Stock 2011 - 2019 Ford Explorer Discussion 1
9 Signature LED Lights Stock 2011 - 2019 Ford Explorer Discussion 77
M Explorer LED Tail Light not working Stock 2011 - 2019 Ford Explorer Discussion 33
V Anyone tired Morimoto LED fogs? Not bulbs but entire assembly. Stock 2011 - 2019 Ford Explorer Discussion 8
L Any LED Headlights for 2015 Explorer out there? Stock 2011 - 2019 Ford Explorer Discussion 5
J Disable LED Signature Lights Stock 2011 - 2019 Ford Explorer Discussion 131
M 2016 Low beam LED angle too high? Stock 2011 - 2019 Ford Explorer Discussion 19
C Interceptor Utility Whelen LED problems Stock 2011 - 2019 Ford Explorer Discussion 7
N 2016 Explore LED Headlight Kelvin? Stock 2011 - 2019 Ford Explorer Discussion 1
N 2011 - 2015 HID & 2016 LED Lumens and Kelvin? Stock 2011 - 2019 Ford Explorer Discussion 1
G 2016 Explorer LED Signature Lights Stock 2011 - 2019 Ford Explorer Discussion 16
U Order 16 - LED Stock 2011 - 2019 Ford Explorer Discussion 4
X Interior Door handle LED out Stock 2011 - 2019 Ford Explorer Discussion 2
B 2016 Explorer LED Fog Lights option?? Stock 2011 - 2019 Ford Explorer Discussion 171
M Trying to install LED lights Stock 2011 - 2019 Ford Explorer Discussion 2
J 2013 Ford Explorer Sport led license plate bulbs Stock 2011 - 2019 Ford Explorer Discussion 8
C Put in my led fog lights and they looks awesome Stock 2011 - 2019 Ford Explorer Discussion 6
P Alarm LED? Surprised there is none Stock 2011 - 2019 Ford Explorer Discussion 6
Similar threads
