david4451
- February 9, 2015
- cotabato philippines
- 2001 ford sport trac
I think we have all been surprised how quickly our new engine oil gets dark looking relatively guickly after a change. Looking on Google and youtube, there are recommendations to flush the engine with diesel or kerosene. One guy on YouTube poured a gallon of kerosene in the oil filler, started the engine for a minute or two, drained engine, then repeated. The result was a lot of black fluid drained from engine that cleared up a lot on second flush.
I would never suggest that anyone should try this type of flush using engine to circulate a lot of diesel/kerose. Just out of curiosity has anyone out there tried this? If so what were the results?
On my next oil change I will flush my ST engine with kerosene or diesel, but having installed a pre lube pump I will use this to circulate kerosene/diesel to clean out engine till it is clear. Then once drained half fill with cheap oil and flush with that to remove residual kerosene/diesel.
Please anyone with advise thoughts etc on this.
