Exhaust Tip | Ford Explorer Forums - Serious Explorations
Exhaust Tip
Kazer
Sneads Ferry, NC
2001 Excursion PSD
ive got a 4.0 SOHC and ive searched the forums here and im looking for an exhaust tip to give it a nicer sound that i can throw on for a relatively cheap price. i just wanna pick up somethin at autozone or advanced auto parts. any suggestions or reccomendations?
thanks
thanks
Exhaust tips are purely cosmetic. If you want to change the sound, you need a new muffler.
ah. alright. so would i be better buyin a magnablow or a blowmaster, or could i just do a straight pipe or something. im not excatly the smartest when it comes to exhaust
magnaflow* flowmaster*
no member i can assure you, will advise a straight pipe... sound is terrible, and theres no real gains, other than gaining unwanted attention lol...
my suggestion, would be go on youtube, and search " explorer exhaust " and find a particular flowmaster or magnaflow or cherrybomb muffler that you like. then go to your local exhaust shop, and have it installed...
im going to list the ( SIMPLE SET UP CATBACK EXHAUST ) for you...
1. remove factory resonater.
2. run 2.5'' pipe from the end of the ( Y-PIPE ) to the muffler.
3. choose whatever muffler you want to install
4. run 2.5'' pipe from the muffler.
5. run the pipe over or under the rear axle ( your choice )...
6. choose your tip of choice, and exit angle ( 45 degree exit or straight out like factory )
*** now i will list the pro's and con's, that i have discovered with this set up
PRO's - 1. increased MPG / 2. increase 5 to 15 HP/TQ ( pending vehicle ) / 3. better towing ability
- in regaurds to increased MPG's just from my experience, i gained about 35 to 40 miles to every tank of gas, so the money you put out will pay itself off in gas over a relatively short amonut of time... I had a K&N INTAKE, and CUSTOM CATBACK EXHAUST to validate the mileage increase for your info...
CON's - 1. loss of low end TQ... but in a sense isnt really lost, but more so moved into the higher RPM's
*** now you may wonder what this might cost you ???
- exhaust shops can vary in price like the weather, but most custom CBE's can be hooked up for as low as 250$, and up to as high as 500$... it depends on what muffler you buy, and how much the shop is going to charge you...
thats the set up i ran on my RED 03 XLS, and what i plan on doing for my new 05 Silver XLT...
hope this helps ya fella !
I'd also like to add an exhaust tip because I'm sick of seeing that rusty pipe. But looking closer, it seems I've already got a tip welded on there by (presumably) the previous owner and I don't feel like cutting. What do you guys think about slipping a tip over an existing tip?
The one that is on there now has a 2.5" outlet and tapers down to a smaller inlet (probably 2.25"). The stock tailpipe is 2". I'm thinking of sliding on a bolt-on tip with a 2.5" - 2.75" inlet and 3" outlet. I figure the cone shape of the existing tip should keep the new one from sliding off easily. Any thoughts?
