  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
factory alarm going off while charging battery
kimm2381
Tulalip, Wa
2004 XLT
Hi there,
I inherited a 2004 4.0 XLT when my dad passed, that does not run. When trying to get in into neutral to load on the trailer to haul home, the alarm was going off while connected to another vehicle, but I was able to lock the doors from the inside and disengage it long enough to get the rig into neutral, but have not been able to get it back into park, no matter what I've tried. Today, we hooked it to the trickle charger so we can start troubleshooting why it's not running, and the audible alarm goes off as soon as the charger is engaged, with the instrument panel completely lit up. I have been able to override the alarm before, but I don't remember how I did it. During this episode, I closed all doors, locked and unlocked it from the inside, with and without the key (factory key) in the ignition. For the time being, we have the battery disconnected, and hooked to the charger solo. Is it possible that the alarm was going off because the battery was so low, and we'll be able to override it when we hook the battery up once charged? I haven't found any threads describing a situation quite like this, so I'm at a loss on what to do. Also, I do not have a key fob right now... I know they are cheap, but I don't really want to order one and find out that the explorer isn't worth fixing.
Any input on both getting the alarm to disengage, and getting the dang thing back into park?
kimm2381
Tulalip, Wa
2004 XLT
no bites yet, but to update... battery is fully charged, audible alarm still goes off as soon as the pos terminal is connected. Found the RAPS module to get the door code, can lock and unlock doors via the keypad, all while the alarm is going off, and does not disable the audible alarm. At this point, I'm assuming I'll just have to take it to ford and pay them to diagnose the issue... or cut my losses and sell it as a parts vehicle
dkl
Northern CA
2002 Explorer XLT, 4.0L
It should easily cycle back into Park if everything works. Insert key, turn to ON position, foot firmly on brake, move shift selector. If it's really difficult to move, you might have a problem with the shift interlock and/or ignition.
What happens if you unlock the truck, pull the horn fuse and connect the battery? Does the perimeter alarm shut off and disarm itself after five minutes? You'll still be able to hear the relays and see the lights flash until it shuts off.
kimm2381
Tulalip, Wa
2004 XLT
We haven’t pulled any fuses yet, I’m going into labor so I’ll save that to try in a couple weeks when I will hopefully feel like tinkering again. It is something we planned on doing (pulling the horn fuse), we just didn’t get a chance too
B 02 Explorer\relay\ford factory alarm Stock 2002 - 2005 Explorers 5
T How Do I Go About Adding a Factory Alarm? Stock 2002 - 2005 Explorers 1
T Add on Sensor to Factory alarm HOOD PIN TRIGGER Stock 2002 - 2005 Explorers 1
M 2004 explorer factory alarm problem Stock 2002 - 2005 Explorers 6
M Factory alarm is driving me nuts Stock 2002 - 2005 Explorers 8
H Factory Alarm "Arm" Wire Stock 2002 - 2005 Explorers 7
T Factory alarm Stock 2002 - 2005 Explorers 4
C Factory Alarm Goes Off Randomly Stock 2002 - 2005 Explorers 7
M Factory subwoofer Stock 2002 - 2005 Explorers 5
S Free Factory Wiring Book for Lincoln Aviator Stock 2002 - 2005 Explorers 0
JW Upgrading cluster and factory head unit Stock 2002 - 2005 Explorers 0
A 2003 factory XLT running board(s). Stock 2002 - 2005 Explorers 6
H What was every single option that was offered from the Factory in a Gen 3? Stock 2002 - 2005 Explorers 0
H Question about the Factory Subwoofer Stock 2002 - 2005 Explorers 28
R Free 2002 Explorer/Mountaineer factory manuals Stock 2002 - 2005 Explorers 2
T Factory Window Tint Stock 2002 - 2005 Explorers 25
T Factory Speed Limiter Stock 2002 - 2005 Explorers 8
T My Explorer Left The Factory Missing Something... Stock 2002 - 2005 Explorers 32
N Seat heater installation if not factory installed? Stock 2002 - 2005 Explorers 3
F Original Spark Plugs from the Factory? Stock 2002 - 2005 Explorers 10
P Replace factory radio/single CD unit Stock 2002 - 2005 Explorers 3
T Factory Subwoofer Not Working Stock 2002 - 2005 Explorers 13
J Time to replace factory shocks Stock 2002 - 2005 Explorers 7
B Factory Wheels for 2003 Explorer Limited Stock 2002 - 2005 Explorers 1
Z factory dvd installation Stock 2002 - 2005 Explorers 2
R Aftermarket radio / factory DVD Stock 2002 - 2005 Explorers 1
S Factory Keyless Entry Code Doesn't Work Stock 2002 - 2005 Explorers 0
A Source for replacement factory uph Stock 2002 - 2005 Explorers 2
I factory subwoofer Stock 2002 - 2005 Explorers 1
T Small factory hitch Stock 2002 - 2005 Explorers 8
W Is there paint underneath the factory trim? Stock 2002 - 2005 Explorers 4
T 2005 Factory Radio removal and replacement Stock 2002 - 2005 Explorers 4
C Factory Subwoofer question Stock 2002 - 2005 Explorers 5
D factory remote start (FOB) Stock 2002 - 2005 Explorers 0
S factory ford remote start Stock 2002 - 2005 Explorers 5
M Factory remote start - need help! Stock 2002 - 2005 Explorers 17
B How to reprogram a new Factory installed Remote Start Remote! 02 Explorer Stock 2002 - 2005 Explorers 11
G Factory Sandwich style oil cooler? Stock 2002 - 2005 Explorers 3
J Factory radios replacement with aftermarket Kenwood. Stock 2002 - 2005 Explorers 7
C What Factory Stereo System Do I Have ? Stock 2002 - 2005 Explorers 2
O Ford Factory Rebuilt Tranny Failure at 16K Miles Stock 2002 - 2005 Explorers 7
B 2003 Ford Factory remote start. Stock 2002 - 2005 Explorers 8
A What is your factory tire size? Stock 2002 - 2005 Explorers 9
K Factory Recalls. What is the best way to go about getting these done? Stock 2002 - 2005 Explorers 4
A Factory relearn?... Stock 2002 - 2005 Explorers 16
M Do the 2004 come with Factory Alarms? Stock 2002 - 2005 Explorers 5
S Factory Clutch After 150K Miles? Stock 2002 - 2005 Explorers 4
D Wanted Factory Class III hitch - Keep an eye out for me, please. Stock 2002 - 2005 Explorers 7
M Factory DVD displays "no disc" Stock 2002 - 2005 Explorers 2
X Factory Skid Plate Stock 2002 - 2005 Explorers 0
Similar threads
