Derek up North
- October 9, 2011
- Montreal
- 1999 Explorer 4.0 SOHC
I've just bought my first Explorer, ('99, 4.0 SOHC with 150k miles). It's got the (apparently very common) flashing 'O/D Off' light flashing at me. No check engine light on and my Equus scanner doesn't find and codes in the OBD2 memory. I've read search results here until my head's spinning. I see mention of reading transmission codes and that some aftermarket 'code readers' don't read them. Is there some way to read transmission codes (Number of flashes?) before heading to a dealer or transmission shop?
If I stop and shut of the engine and then restart, it no longer flashes but starts flashing again a few miles down the road. I don't notice any change in drivability before or after.
I've read to disconnect the battery for 15 minutes to erase all codes and reset the memory, but am wondering if I'm not better off keeping any 'hidden' codes in memory for a shop to read?
I haven't noticed any hard shifting, but since the light started flashing I've been driving VERY gently. I honestly can't say if it's shifting into O/D or not because the tach isn't working (seperate problem, I suppose). Haven't tried shifting into 4x4 (Hi or Lo) because I don't want to do anything to make things worse.
Any help would be appreciated. Thanks in advance.
TTFN
TTFN
