Jim Fidler
- May 20, 2007
- Arlington, Texas
- '02 Limited V8
I have an early build (summer 2001) 2002 Limited V8 2WD 49K miles, 5R55W/S, fluid changed at 30K, no trailer towing, very well maintained and lightly used. O/D light begins flashing sometimes (sometimes not) and no noticable change in shifting or noticable problems. Seems to shift normally. No OBD II codes found with Actron new CP9125 key on, engine off or KOER. Same for Autozone. Do I need to pay Ford dealer to read codes with NGS or eq? Ford "Workshop Manual" says "TCIL (O/D OFF light) will flash if EPC solenoid circuit is open, shorted to battery, ground, OR if a fault has been detected in a monitored sensor used for transmission purposes." From this it sounds like the EPC solenoid or wiring is bad....assuming there are really no codes stored.
Does an OBD II scanner ignore Manufacturer Specific Codes? Or, does it just report the code number without further info?
Thanks
Jim
Thanks
Jim
