Hello,
sorry to bring this up in a seperate thread since I found tons of them in a search but here goes anyways.
Just today I got the truck back together after a month long fiasco changing the heater core and dropping the exhaust pipes to change all 4 o2 sensors and weld up a leak. This is a 98 Explorer 5.0 AWD. Truck started right up and I noticed the O/D OFF light flashing. CEL is not on and my code reader isn't pulling any codes out. This has never happened before this job previous to tearing out the dash/column/computer. Another worry is that during the exhaust R&R I took off the crossmember and jacked the tranny up into the floor boards to gain clearance to drop the pipes. Possible there's some magic sensor or something up there I broke? I didn't hear anything when I jacked it up to indicate crushing something. The truck seemed to shift fine when I drove it around the block. Now the truck also spent weeks with the front end jacked up about 8 inches higher than the back end if that would cause some kind of fluid movement that needs to settle or something. Any ideas? I had to pull half of the motor apart as well to get the heater tubes off, maybe something I'm missing when I put it back together and just can't see the hanging wire?
Any ideas would be GREATLY appreciated!
Thanks,
Dennis
Thanks,
Dennis
