aldive
Elite In Memoriam
- January 17, 2001
- 1999 XLT
I have been having a delayed crank to start problem. Well tonight I hooked up a fuel pressure test gauge.
The fuel pump makes the standard noise with the key in the run position; however, the gauge reads about 5 pounds of pressure. This is true after several cycles of key on key off.
Upon cranking, which is immediately after a couple of key on “prime” sessions, the pressure is a rock steady 65.
Further, after turning off the truck, the pressure drops to almost zero immediately.
The truck runs great, with full power and gets typical mileage.
Any ideas or suggestions on what to do next?
