Donner
- October 21, 2007
- Natomas/Irvine
- 01 Sp 03 XLT 4x4s, Scion
grounding...
From the relay, 87 is grounded to the body. Each light is grounded individually in their respective locations. Is this acceptable?
Thank you!
Nooooo!
stop right there--
You need to run a new 12 volt source wire back there, preferably right off the battery. You might want to consider getting a power block.This lead should be fused within 18" of the battery.
You then connect a relay to the "existing" light wire, using it for a "trigger" to switch the relay on.
Then, the new power wire is connected to another pin on the relay-and the power lead from the "new" light(s) to yet another relay pin.
the light(s) circuit is then grounded, as is the relay.
You should be able to google a relay schematic.
Never increase the value of an existing fuse!!!!!!!
Thank you!
