found the hole, only had 2wd, went in and i felt the rear axle lift up and i lost traction and it sank, engine stayed runing entire time i was waiting to get pulled out, i got pulled out and let the water out then picked a different line and went back in with the same result........only damage i have really found is my clutch is a little weak (i think i got some stuff in the pressureplate holding it off a little, and i think i got a fuel pump relay wet....other then some stinky seats all good to go
this is my 4th? time being in water that deep, full height snorkel relocated pcm and all breathers and alot of dielectric grease pigtails and a few other things
