Explorer Forum Covers the Explorer ST, Explorer Sport, Explorer Sport Trac, Lincoln Aviator,
Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Ford Aerostar
Register Today It's free!
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
hatched91 going from leafs to coils
- Thread starter hatched91
- Start date
Add an avatar, upload photo attachments, and more!.
hatched91
- October 2, 2005
- godfrey, Illinois
- 1997 sport ohv 5spd
after a good 16hrs of work, i have come to the conclusion that this conversion does not work correctly. In order for the springs to sit upright without leaning over, the axle would need to be a couple of inches wider. My truck is still currently sitting in my friends shop. Here's what happened. The drivers side(surprisingly) met up just fine, it was the passenger side that i could not get to meet up correctly. I resorted to grinding the flanges off of my weld on C brackets and still couldn't get enough room. I suppose if you ground down the outside of your casting a little for the steering knuckle and then boosted up your coil seats about an inch, then you could possibly pull it off. I have plenty of pics, but my camera is in my truck about 45min away. Lucky for me, the coil buckets, radius arms, etc had a full width d44 that i'm going to use. I guess i'll be grinding off the coil buckets to space them out tomorrow. so here's the laundry list of problems.
hatched91
- October 2, 2005
- godfrey, Illinois
problems:
1) couldn't get the springs to sit up straight, the passenger side always leaned
2) Axle tubing was not wide enough to sit the coil seats out correctly
3) I could not get the axle to straighten itself out, it always pulled to the drivers side
4) the coil seats smashed against the knuckle casting and just bent when torqued down
hatched91
- October 2, 2005
- godfrey, Illinois
I have a MAJOR PROBLEM! when i drive this truck down the road, if i go over 20mph it starts to jump around from side to side. What is causing this? I forgot to space the coil buckets out from the frame, but i'm guessing track bar...should i lower the track bar down? I have it to where the the sudden curve on the axle end is curved up but i think it was the other way around stock, i don't know.
IZwack
Moderator Emeritus
- February 5, 2003
- Germantown, MD
- 1998 Ford Explorer
Just make sure the panhard is as close to parallel as you can get it to the steering link from the steering gear box. And dont compare the bar themselves -- instead look at the straight line that goes from mounting hole to mounting hole (the panhard could be an ellipse if needed so dont look at its shape). As for the jumping from side to side, you need a steering stabalizer (a shock). But also, looking at the chassis-end panhard mount, I think you need to brace or weld that better (trust me on this one, I've redone mine after ripping the chassis plus 1/4" thick plates in Paragon).
CodePoet
- July 11, 2002
- Indianapolis, Indiana
- 1993 XLT
Your trac bar should be in the same plane and length as your drag length (or as close as possible). Lowering the top mount can lead to bump steer as the two will no longer be traveling in the same arc. It sounds like you have death wobble. Check your trac bar bushings, if they are good check the actual mounts on the axle, they can get ovaled out and cause issues. If it is ovaled out you can mill out an insert that can correct the issue. Also...get those buckets spaced out.
And like iz said...re-enforce that trac bar bracket.
IZwack
Moderator Emeritus
- February 5, 2003
- Germantown, MD
hehe hatched91 -- I'm not trying to be mean or anything but sounds like you should have done more measuring before you did the swap to coils
But you're almost there, you just have some minor kinks to work out and I'm sure you'll be flexing in no time.
hatched91
- October 2, 2005
- godfrey, Illinois
well this is my daily driver, i don't much care about 4wd or flex at the moment, i'm just trying to get it moving again faster than 20mph haha. sounds like i need a new trac bar. I also definitally need to reinforce that mount. I am going to cut the trac bar apart, and make it straight instead of a curve. I replaced the bushings with brand new ones because my wise self cut and welded with the bushings in it and they caught on fire. D'OH! oh well. I do not understand what you guys mean by parallel bolt holes. Do i want the actual trac bar to be parallel to the drag link or do i want the trac bar to end at the same height and spot as the TRE that connects to the pitman arm?
IZwack
Moderator Emeritus
- February 5, 2003
- Germantown, MD
Two things:oh, it isn't possible that the way the coils are curved could be causing this?
Either the axle-end of the coils are too far towards the centerline of the vehicle
or
At least one of the mounts of the coil isnt perfectly horizontal (I'm betting its the upper coil mount thats leaning too much towards the centerline of the vehicle). As the coil is weighted, its top is seated at whatever angle the coil-mounts are set at - which causes the bowed-out appearance.
hatched91
- October 2, 2005
- godfrey, Illinois
oh, yeah i know why it's bowed out. I need to put the coil bucket spacers in, 2x6" stock steel. BUT i am trying to figure out how to set up my trac bar.
- January 27, 2002
- Texarkana AR/TX
- 94 SAS sport
Your current trac bar angle is good. Did you butt-weld in a splice to the tracbar?
I think your street driving problem is caster. What does your caster look like? Its really hard to tell from pics but it appears that you either need to cut/turn the knuckles or bring the pinion down.
IZwack
Moderator Emeritus
- February 5, 2003
- Germantown, MD
What I meant was, unless the panhard bar and the steering link (that connects the gearbox) is perfectly straight and has no kinks or bends, use an imaginary line that goes from the panhard's axle mount to the panhard's chassis mount. In other words, you could have a heart-shaped panhard bar and still have it parallel to the steering link even though it probably does not have one section that is parallel to the steering link. But from that one picture you posted, it looks pretty good.I do not understand what you guys mean by parallel bolt holes. Do i want the actual trac bar to be parallel to the drag link or do i want the trac bar to end at the same height and spot as the TRE that connects to the pitman arm?
JoshC
Only rolled it once honey
- May 1, 2000
- Culloden, WV
- 97 4d OHV
In other words, you could have a heart-shaped panhard mount...
Valentines day is over
IZwack
Moderator Emeritus
- February 5, 2003
- Germantown, MD
With you in my life JoshC, everyday is like ValentinesValentines day is over![]()
Similar threads
- Replies
- 52
- Views
- 106,784
