nolaDre
- February 9, 2022
- New Orleans, LA
- 2017 Explorer PIU
I have a 2017 PIU. I ordered and received a 2017 Explorer base model center console. I thought it would be an easy swap. I noticed that my PIU doesn't have matching wiring. It does have the most important wiring to me and that is to power the usb port.
The first major issue became apparent when I couldn't get the console to slide into place. I was doing this with the top bezel of the console removed (cupholders). I went with an easy solution and clipped off some plastic that was in my way. I could now slide the console to where it needs to be situated and clip in the trim that goes along the footwell.
I tried sliding the top bezel with cupholders into place when I realized that the metal bracket under the radio is in the way.
I have pictures below to try to explain what I encountered. (Sorry about the glare, I have a rear camera lens protector which is blocking some of the flash)
Is this a well known issue that I'm not aware of? I had naive expectations that I could just pop it into place.
