Help choosing an Explorer | Ford Explorer Forums
Glock40cal
St. Charles, Missouri
00' XLS
Hello everyone. I am looking at buying an Explorer and i was wanting everyones opinions on which one to get. Currently i am driving a 93 Ranger and need a vehicle with more room, cant fit me, the little lady and our daughter in the cab at the same time, and the LOML just dosnt like to ride in the back. ;)
Right now I am looking at either a 98, 99, or a 2000 and was wondering what everyone opinion on the best one is.
Does one year seem to have more troubles than the rest? Which engine is more reliable, the 4.0 v6 sohc or the 5.0 v8? Any major recalls I should be awhere of? I would rather have an engine that is more reliable/less common problems than one with better gas milage.
Thanks in advance
I would look at the V8's for sure. The drivetrain is much more reliable and the mileage difference between the two is minimal.
V-8 all the way. A 4.0 from that era is likely (not destined, but LIKELY) to have only a few more years of reliable service left in it.
My '99 4.0 crapped out a month ago- traded it for a ranger of all things.
Mom's '96 5.0 V8 is still running like it's showroom new.
I wouldn't say that. It's not unusual for a 4.0L OHV to easily go at least 250,000 miles. It's a bit unknown for the 4.0L SOHC they haven't been around as long. But I would still go with the V8.
V8 is probually the better choice, but I'd go with the '97 V6 4.0 SOHC just because I've had mine for 5 years and have had no problems what so ever.
Wow, thanks for all the replys so far. Are all the 5.0 V8's AWD? Is there anything in paticular i should look for that is a common problem?
If i were you, i wouldn't look into a explorer, or any ford for that matter, i have had very bad luck with mine, seems to be a money pit. But when it does run right, i do like it. its definately hit or miss
98-00 are all pretty similar. As someone else said, get the one with the lowest mileage. Obviously you want it to be in good shape too. I scored a '99 Eddie Bauer about 1.5 years ago with only 32,000 miles on it (6+ years old). V8 all the way. I like SOHC (I've had 2), but much prefer the 5.0.
Unfortunately, no. But you can swap in a 4x4 selectable transfer case from an F-150. It can be a lot of work, but I think it's well worth the effort.
Well 4 months later i finally bought one. :) The Ranger's leaf spring shackels rusted out so i decided to make a purchace. Wanted to get the 5.0 V8 but didnt like the idea of AWD. Ended up buying a 2000 XLS 4X4 4.0L V6 OHV with 66178 miles on it. Very clean and runs good. Wanted the SOHC but couldnt pass it up for $5400
It has a whine that im not sure if i Should be concerned about. Does it when idleing and while moving but only until about 30 MPH then it seems to go away.
At first i thought it was the power steering pump but it does it without turning the wheel.
After a little research im leaning twards the "1st Gear Whine" i've heard about on here but not really sure what it is exactly.
Anyone have any additional info?
I'm not trying to steal the thread but there is a guy on rangerpowersports forum that said he owns a garage and has part delivery trucks with the sohc with over 300k mile on them.
