BrianDye
I'll have another...
- March 1, 2009
- Monroe, MI
- 2006 XLT
Got everything off and removed with NO issues, axle nut, caliper bolts, even the hub bolts to me were easy.
Now, since early this morning, I have been out in the garage beating this hub to death trying to get it off.
There are just 3 bolts holding it to the knuckle right? I already started to push the axle in a bit so I know thats not stuck.
I have heated it for 5 minutes with a propane torch, used 1/4 bottle of WD40, dont have PB blaster handy, or id have used that, beat up and down on the studs, tried a chisel and hammer right in the crevice where the hub meets the knuckle, even put a large pipe wrench on the top of the hub, and hit it numerous times with a 2 or 3lb hammer, and NOTHING.
I even tried the method I found on YouTube, where you put one of the bolts back in the hub, and use your power steering to push an extension against the bolt. Bent 2 extensions, and got NO movement from the hub.
I am literally at my wits end, even priced out a new knuckle, but I already spent more than I can afford at the moment on both OEM hubs.
Any suggestions? I dont have another vehicle handy right now either, unfortunately. Wont until tomorrow when the girlfriend gets home.
