Carguy3J
- June 21, 2008
- North East New Jersey
- '99 4dr. XLT SOHC A4WD
Ok, so I just got the front end mostly apart, on my '93 Ranger, 4x4, in order to do the '95-'97 brake upgrade, and do new ball joints, etc..
I replaced all the u-joints a couple years ago,with Duralast Gold non-greasable parts, in the front outer axle shafts. When I just pulled them out, one side of the "cross", on both shafts, is "squeaky" and feels dry. Given the minimal useage in 4wd, I think the joints are still good. They just need greasing. If I could, I would just replace them, but that's not an option. I don't have another working vehicle, so going out for parts is also not an option. I have an appointment for an alignment tommorow at 3pm, so this has to go back together.
I would rather not attempt to disassemble the joints, as a.) It will be time consuming, and b.) That risks a whole 'nother can of worms, due to rust,etc..
So, what about drilling a small hole in the end of each cap, to inject some grease, and then seal it back up? I can't just put in grease fittings, because there is no clearance to put the axle back through the knuckle. Would RTV last,and hold the grease in? What about JB weld?
I need some quick advice on this, as I have to proceed early tomorrow morning.
